Old 11-03-2018, 09:40 PM   #1
usersci
Drives: 1.5
How to take off crank timing sprocket
150,000mi 1NZ FE engine has been making noise lately under the timing cover. I replaced the water pump and it was still rattling mostly at like 1800RPM.
I could afford to ground it for a few days so I bought a new timing chain kit complete with the sprockets.
The old chain compared to the new was pretty identical. The gears showed very very slight wear.
I decided i'm just going to change it anyway to rule out an issue. My new issue is I have no idea how to take off the crank sprocket.
https://imgur.com/a/rujpvQG
With the timing kit they gave me a sprocket that's barely over the crank end and way too small to get over the second lip where the installed one appears.
usersci is offline   Reply With Quote
Stock (factory) yaris Timing ? salmanghiyas Performance Modifications 44 03-29-2015 03:50 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
timing chain or faulty sensors almcheung DIY / Maintenance / Service 3 08-16-2011 09:33 AM
crank, fire, hesitate, crank, fire, run, gas smell twowheels General Yaris / Vitz Discussion 9 06-25-2009 07:11 PM
