07-29-2009, 11:37 PM | #1 | |
USAF_SrA_E-4
NEED HELP
I tried to change the turning signal lights puting 2057LED insted of 992(7440A) wich are the one for it Well now my turning signals are not working at all or the hazard ones ANYONE KNOWS WHY?Could it be a Fuse? But where is the Fuse box and what fuse is it?
07-29-2009, 11:41 PM | #2 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
when you say you tried to replace it, do you mean you put the old ones back in after the new ones didn't work?
07-29-2009, 11:46 PM | #3 | |
Drives: 2007 Yaris S Join Date: Jan 2009
try what he said put the old ones back, and if that doesnt work, then it might be the fuse
Project LEGATO |
07-29-2009, 11:54 PM | #4 | |
USAF_SrA_E-4
I did try that to but i was replacing the left side and the right side isnt working
07-30-2009, 12:28 AM | #5 |
there is no light from any corner of the car when you flip the hazards?
highly unlikely that you popped a fuse as the bulb itself acts like a fuse to begin with, but if you reinstalled the original bulbs then yeah check the fuses. |
07-30-2009, 11:07 AM | #6 | |
USAF_SrA_E-4
Yup I tried switching the bulb to the original and the led one as well and no results I need to find where is the fuse so I can check them if not... as much as I dont want to im gonna have to take it to Toyota
07-30-2009, 12:36 PM | #7 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
It's the 10A one labeled "TAIL" in the fuse panel that is up under the dash (i.e. the one you put your head on the brake pedal to see).
07-30-2009, 12:41 PM | #8 |
A 2057 is a bayonet mount and a 7440A is a wedge mount.
Out of curiosity, how did you install it? |
07-30-2009, 01:01 PM | #9 |
'09 Yaris
With duct tape and bailing wire.
Just trying to add some humor. S.R. |
07-30-2009, 05:10 PM | #10 | |
USAF_SrA_E-4
Well its the tail lights from Garm so the bulbchanges its not the same plug that the original taillights comes with
07-30-2009, 05:35 PM | #11 | |
Did you find that the fuse was popped? |
07-30-2009, 10:35 PM | #12 | |
USAF_SrA_E-4
I havent checked to much work I will try and see wich one and where it is I will post some pictures of the plug for the bulb so you can see.
Yes its all rewired but they been working for almost a year and now that I wanted them LED amber lights this crap happens I PRAY TO GOD IT'S JUST A MESSED UP FUSE!!
07-30-2009, 10:37 PM | #13 |
The lighting circuits are well protected, so I would almost guarantee that it's the fuse.
07-30-2009, 10:39 PM | #14 | |
USAF_SrA_E-4
hopefully...
07-31-2009, 03:23 PM | #15 | |
USAF_SrA_E-4
Here are the picture i took some of them off and checked them the ones i did are good the thing is wich one is tha one for the signals?!?!
07-31-2009, 03:32 PM | #16 |
The 10A one at the bottom left of your picture is the tail light fuse if you are working on a liftback.
By the way, I'm not digging that white wire stuffed in the meter fuse. I don't think it's part of your current problem, but it's not a good way of doing things... |
07-31-2009, 03:39 PM | #17 | ||
USAF_SrA_E-4
07-31-2009, 03:47 PM | #18 | |
USAF_SrA_E-4
If is that one its intact
Thread Tools | |
Display Modes | |
