Old 09-06-2013, 04:03 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Factory rear fog lamp ?
I have a 2005 Vitz RS (JDM). What I thought was just my rear reflectors also seem to be the fog light. In my Japanese manual there is a diagram showing the replacement of the bulb there. Also i have seen another RS with those lights lit up. I spent a few mins looking around in my car and could not see any easy way of checking if there is a bulb or any wiring there.
Anyone have any advice on how I can check it ?
i've put a pic of my reflector/light
Its the ones on the bumper.
JudgeM is offline   Reply With Quote
Old 09-06-2013, 06:32 AM   #2
Peek up under the bumper and see if there is a wire going to one or both of them. I think that the reflectors are only replaced with lights in certain markets.
Old 09-06-2013, 10:59 AM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
The ones that you have are the rear reflector-type.
You can buy the rear fog lamps but mostly likely you'll have to wire them up yourself. The rear fogs look like these.
Old 12-30-2013, 11:32 PM   #4
JudgeM
JudgeM's Avatar
Where can I buy these from ?
Old 02-04-2016, 07:23 PM   #5
Jerkratt
Jerkratt's Avatar
Were can you buy the car side harness? Or does anyone know how they function? Are they essentially extra running/brake light? Or is there a switch for them like Audi?
"It hurts more when its wet"
Old 02-04-2016, 08:04 PM   #6
On the Yaris / Vitz from areas where they are factory installed, they are controlled by the rear fog light switch and relay, which are separate from the front fog light switch and relay. I appears also that the rears can only be turned on when the headlight is on and the front's are on.
Old 02-04-2016, 08:09 PM   #7
Jerkratt
Jerkratt's Avatar
So I have the rear fog lights and I have the rear fog light harness what I essentially want to do is make them work like factory the problem is my car side plug only has two wires the fog light harness has all 10 if I remember correctly wires pinned to the connector. How can I obtain this switch and relay? Everything is installed (fog and harness wise only thing that works is 1 of the 2 license plate lights as I have the JDM bumper)
Old 02-04-2016, 08:13 PM   #8
Jerkratt
Jerkratt's Avatar
I should also add I have factory fogs and already removed my DRL Relay (ground out fog wire). Does the switch give option to one or the other? Or both at same time?
Original tail light without rear fog light for Yaris 3dr 2009-2011 Ot_tO Cosmetic Modifications (Exterior/Interior) 9 08-07-2012 04:27 PM
Replacing factory fog lights? jmk1983 DIY / Maintenance / Service 4 10-13-2010 04:39 PM
