shiny for 10 minutes
I bought a weaponR exhaust manifold. it was shinny. I only got to look at it for about 10 minutes.
now it's not shinny anymore :( unshinified |
Yeah but header wrap makes it look legit!
it also helps with flow and scavenging. plus, that computer being 6 inches from the manifold scares me...
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
You have great taste sir.
![]() Personally I think you went a bit over the top with the wrap, but it does look very nice. ![]() I've been running mine for nearly 2 years with no wrap or heat shield, and never ran into any problems. ![]()
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
tri Y makes for better low end torque. :) I didn't by the DC one because i'm not looking for top speed. I am looking to go quickly....
and the wrap helps on any engine. higher temperatures (to an extent) creates higher pressure/flow, which creates better scavenging from sister cylinder, which is exploited by the try Y pipe. (as the theory goes) |
![]() Drives: 08 Yaris hatch back Join Date: Nov 2016
Sweet looks awsome
![]() ![]() Drives: 01 Yaris TS Join Date: Jan 2017
Looks good, how does it perform? (butt dyno ?)
I have a spare stock manifold.. I should wrap it for educational purposes ![]() |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
be sure to port-match the header to the gasket. There is some shrouding on them. Plus while your at it, investigate the inner joints & blend as necessary. Mine had some really rough joints
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
XP10 Enthusiast
Drives: 2000 Echo Coupe Join Date: Jan 2017
That looks awesome! Now I want one
![]() I always wondered if this Yaris parts fit in a 1st gen US-Spec Echo. It's the same engine though.
'01 Yaris 5dr Hatchback M/T | Blue Streak Metallic [RIP] '00 Echo Coupe A/T | Absolutely Red [Still Alive] |
Obsessed with 1.5L
^ outlet flange bolt pattern is wider for the yaris and the outlet is in a slightly different position. You can probably use one...just modification to your front pipe will be needed.
#11 | |
XP10 Enthusiast
You mean like replace the bolt pattern with another aftermarket pipe? or maybe adapt the OEM outlet flange? I was thinking about adding a aftermarket pipe and/or exhaust from newer models and customise to fit....
Tags |
exhaust manifold, exhaust wrap, weapon r, weapon-r |
Thread Tools | |
Display Modes | |
Yaris dead then minutes later starts fine | vinny121 | DIY / Maintenance / Service | 6 | 02-27-2015 08:01 PM |
DIY how to change you belt in 10 minutes without breaking VVTI solenoid | YarisSedan | DIY / Maintenance / Service | 2 | 04-12-2013 10:41 AM |
Shiny glass-looking plastic flakes from HVAC, and windshield | LugNut | New YARIS Purchase Forum | 15 | 11-20-2011 10:39 AM |
