![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
A/C oil type and how much ?
I believe the freon leaked out of my condenser after that small crash the other day.
If you replace the condenser how much and what type of oil should you put back in? I've read online that it only uses about 3 ounces of oil total and PAG 46 Is okay to use, can anyone confirm that ?? |
the condensor carrys no real amount of oil only oil vapor, and you shouldnt need to add any oil if only replacing components
as far as actual oil capacity the only way to be sure is to drain the pump and check directly with the compressor type and spec .....the specs are very specific to pump ID not year/make/model of the car and often times you have mid yer changes that may slightly change the compressor and how much oil its got |
#3 | |
A/C
Authorized Toyota dealership nearby organizes an action "get ready for season" every spring where they prepare the AC system - suck all the refrigerant and oil out, test the system and refill it with the correct ratio of refreshed (removed humidity and debris) refrigerant and oil.
When I had a chat with them, they confirmed what you have mentioned: people tend to add oil when adding refrigerant at home and it is wrong is in most cases it leads in too much oil in the system. If you are not sure what is left in the system, it might be worth giving this to the service center where they can suck it all out first and also run the test to ensure the AC system is completely sealed? It takes 35 USD here (plus the cost of refrigerant), it includes deep cleaning of the AC system etc... |
#5 | |
so long as you have a vacume pump and the ac guages to do it yourself its actualy simple....even still if you dont, so long as you put in a new dryer and filter into a SEALED system your fine, i wish i could remember what oil i put in the compressor as it was used and i did a reseal on it along with new oil every stitch of tech i could find regarding oil is that yes..oil vapor travels with teh freon but should be minimal at best, the "important" oil stays with the compressor, any oil in the system with the freon is just a side effect that shouldnt be there |
#6 | |
freon
to be clear its not for "these cars"..toyota does not make them, and toyota doesnt have the correct specs as even toyota doesnt know what compressor was put in your car or what revision..they just know its "style x"
you need to look up the part number for your EXACT compressor and run it thru the manufacturers database (not toyota)to get the right oil type and amount as well as the step by step verification of oil level there are atleast 6 different compressor numbers used on our cars as there were revisions that changed how much oil and even type in fact there are 3 different possible compressors just for 2007 ....yes toyota lists only 1, but when you dig deeper into the actual model number of the compressor(which is where you get the REAL information) thats when you find out about revisions.... simply put..you need to pull the number off the stamped plate on your compressor and run it thru uhh sanden?'s website i was in your same boat when i was doing my retrofit...and got rather overwhelmed till i got an understanding of the fact that its the compressor serial number and part number that dictate the oil |
#8 | |
okay got it
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
just add an ounce of oil and an ounce of dye, cal it a day, its not going to affect anything or make the compressor blow up, ac parts are forgiving in that manner
A/C specs
Thanks everyone for your replies and support. i did manage to find the information i was looking for on another post. It turns out that the condenser does need 1ounce of oil and it's ND-OIL 8 or equivalent if you're replacing the condenser.
Thread Tools | |
Display Modes | |
