05-28-2018, 08:16 PM | #1 |
Drives: 2008 Yaris Base Hatchback Join Date: Nov 2010
Soft unidentified tinkling noise audible at low speed
I hear a noise at low speed when driving my Yaris with the window open. The best way to describe it is as a tinkling noise. A relative thought it might be a pebble in a hubcap. That's a good description, but I had & have no hubcaps.
It's not loud enough to be heard at higher speeds, especially with the window closed. I've been hearing it for at least 2 years, and it does not seem to be affecting the vehicle in any way. The Yaris is just a month shy of 10 years old. I bought it new. QUESTION: Does anybody have any idea what the noise could be and if it is important? Thanks, R. |
05-29-2018, 12:40 AM | #2 |
My friend experienced something similar, it was coming from rear right wheel. The exhaust muffler was the culprit - while it looked pretty solid outside, there was something loosened inside - it was tinkling and rattling a bit in low RPMs. With higher RPMs the noise was gone - probably the pressure of the fumes did its job.
I am not saying that this is your problem too... just that I have experienced this. :) |
05-29-2018, 07:44 AM | #3 |
Drives: 2007 2-door hatchback Join Date: Jul 2016
Soft unidentified tinkling noise audible at low speed after wheel change
A month or so ago I installed the summer treads (on circa 1990 Miata steelies w/ a 2 year old powdercoat, leaving the wheel-to-hub/drum interface dry and free of any lube except around the center holes.) and immediately started to hear a "Soft unidentified tinkling noise audible at low speed."
Only other things I did were rattle-can the circa 1990 Tercel steel acorn lugnuts w/ rust converter and squirt Corrosion Block on all seams and fasteners I could see from underneath the Yaris. No idea of noise source. Not hearing it now. |
05-29-2018, 02:56 PM | #4 |
Thanks Dogsride and komichai,
Any other comments from you or anybody else will be welcomed. R. |
06-05-2018, 05:37 PM | #5 |
Drives: 2007 Toyota Yaris Sedan Join Date: Mar 2013
Could be a small stone stuck in one of your rotors. I had the same symptoms in my 07 sedan, even took a video to show the sound I was getting at low speeds. I had to take the wheel off, remove the caliper, and remove the rotor - and the stone fell right out onto the ground. Hope this helps.
https://youtu.be/79KPXKrsZao |
06-06-2018, 12:25 AM | #6 | |
That might be the problem. I'll check. R. |
Tags |
low, noise, speed, tinkling |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
LOW RPM @Idle speed = Bad Volt Generation? | jp_costarica | General Yaris / Vitz Discussion | 4 | 06-14-2012 04:56 PM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
Low road noise in Yaris? | RedRide | General Yaris / Vitz Discussion | 32 | 05-30-2010 08:49 PM |
Low idle speed | gonzo452001 | DIY / Maintenance / Service | 9 | 02-21-2007 08:41 PM |
