Old 02-05-2007, 06:29 PM   #1
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
gas gauge and wiper jet spray
most two problems: with all this cold weather as anyone else had the problem than when the last bar is flashing you fill up completely and the fuel gauge doesn't correct itself?
Today I drove to work which is about and hour with traffic and it stayed flashing. Only on the way homei hit a bump and it finally corrected itself. it been the third time so far. But when it does that does the computer know that the car is full or not?
for the wiper jet spray got it replaced with the tsb but it just as bad! Does anyone know if there is an after market one i can get like the old version where you can control yourself where the spray is going? thanks
Adriaan is offline   Reply With Quote
Old 02-05-2007, 07:19 PM   #2
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
spray nozzle: try putting something under the nozzle so as to change the spray orientation. it worked for me. don't try to modify the nozzle outlet - this didn't work for me = 25$ a new one
hystria is offline   Reply With Quote
Old 02-05-2007, 08:09 PM   #3
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
If you mean the one that you can change the direction of the spray with a needle, then you may purchase one for a toyota echo
10 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 02-05-2007, 08:22 PM   #4
ChinoCharles
Drives: LB
Get some LED jets... your car will look like it has a lazy eye. The sprayers are off kilter.
Old 06-03-2007, 02:13 AM   #5
Jerkratt
Jerkratt's Avatar
kinda funny i got white nipple lights that im going to wire to my blinkers and a switch to override and be always on or off... i noticed there not centered but w/e if i dont like it ill take the LED's out and leave the chrome washer nozzle lol
"It hurts more when its wet"
