Old 10-05-2021, 06:22 PM   #1
supermoto
Drives: 2007 yaris ce
would a 2005 echo auto trans fit in a 2007 yaris
nothin about improving the performance, I just have one echo 2005 auto trans on hand and would like to know before spliting both cars apart if it would work out? thanks
supermoto is offline   Reply With Quote
Old 10-05-2021, 09:44 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Unlikely. The Echo uses the C150, the Yaris uses the C50. Key differences could include some or all of the following: mounting points, shaft splines in the differential, cable linkages, wire connectors. The engine block, starter and torque converter/flex plate should line up but that's about all that is likely to mate without serious modification.
2005 echo rs steering wheel compatible with 2007 yaris??? Xlt00 Cosmetic Modifications (Exterior/Interior) 2 01-11-2018 04:53 PM
Toyota Yaris 2005 semi auto doesn't start nihad DIY / Maintenance / Service 0 10-26-2017 04:16 PM
