11-16-2021, 02:12 AM | #1 |
Drives: 2008 1.5L BLUE YARIS Join Date: Nov 2021
ATF and Filter Change.
Hello. I just bought this ATP filter kit and 4 quarts of Toyota ATF WS. Is there anything else I might need like a crush washer for the drain plug? Also wondering the filter and pan torque specs. I read somewhere on here 8FT/LB for the filter and 5.75FT/LB for the pan. Is that accurate? Doesnt seem tight enough....
11-16-2021, 04:37 AM | #2 |
Drives: 2008 hatch Join Date: May 2021
Cut and paste from 2007 repair manual:
Install the oil pan with the 19 bolts. Torque: 7.8 N*m (80 kgf*cm, 69 in.*lbf) Install the valve body oil strainer assembly onto the automatic transaxle with the 3 bolts. Torque: 11 N*m (110 kgf*cm, 8 ft.*lbf) |
11-16-2021, 04:41 PM | #3 |
Thanks for confirming
11-27-2021, 01:28 PM | #4 |
Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
I went without the crush washer and it hasn't leaked a drop. I never replace crush washers unless there's oil on the drain plug when I start the job
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Transmission flush, brake bleeding and oil change | 06YarisRS | DIY / Maintenance / Service | 7 | 08-20-2020 06:15 AM |
Snapped off an ATF pan bolt | bairjo | DIY / Maintenance / Service | 13 | 03-14-2019 03:38 PM |
Complete flush for ATF change? | Lance16 | DIY / Maintenance / Service | 29 | 07-05-2017 09:26 PM |
Replaced my ATF | markitect | DIY / Maintenance / Service | 6 | 01-02-2014 10:10 PM |
2007 Yaris 3 dr hatch ATF transmission capacities | emgconsulting | DIY / Maintenance / Service | 1 | 07-22-2013 06:21 AM |
