Old 08-26-2019, 07:44 PM   #1
sgtpimienta
Drives: 2007 Toyota Yaris
Exclamation Climate Control Knob and Gear Shift Lightbulb Replacement
Hello,
For the life of me I cannot find what lightbulb part numbers I need for the climate control knobs (all three of them) and for the gear shift light thing. I can't see at night if I'm changing from Reverse or Drive. I also can't see the temperature knobs at night either.
I have a 2007 Toyota Yaris 3-door hatchback.
Thanks for your help!
sgtpimienta is offline   Reply With Quote
Old 08-27-2019, 05:35 PM   #2
B.B._07
Drives: 07 5dr
Gear shift indicator bulb is a #74 mini bulb, climate control is most likely the same.
Old 08-28-2019, 04:44 AM   #3
komichal
Not sure if I can help but when I asked the authorized service center to replace one of the bulbs for the climate control they had to order a set of three as they cannot be ordered as one piece (at least not as "genuine part"). That makes me think that those bulbs are rather special and not advised to be inter-changed with standard W5W or whatever we normally use.
Anyway, check this - you may find the answer you need here:
http://www.yarisworld.com/forums/showthread.php?t=44520
Old 09-02-2019, 04:21 PM   #4
Brighton
Knower of little
Drives: None
The center console bulb is marked as a 74 but an aftermarket 74 won't work in the housing for whatever reason, but use one of the LEDS linked below and take the LED out of the housing it comes with. I just did this on mine and it worked perfectly. (plus it'll last forever)
https://www.superbrightleds.com/more...l-led/709/973/
Brighton is offline   Reply With Quote
Old 09-02-2019, 04:38 PM   #5
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
The 74 bulb will fit, you just have to bend the contacts away from the bulb body slightly. I went thru the same thing a couple of months ago.
http://www.yarisworld.com/forums/sho...79&postcount=7
2007 toyota yarisz
6speed manual gear knob miiser DIY / Maintenance / Service 4 05-22-2017 04:01 PM
6 speed manual gear knob miiser Cosmetic Modifications (Exterior/Interior) 0 05-18-2017 02:47 AM
Shift Knob with LED Gear indicator Ferret_san Cosmetic Modifications (Exterior/Interior) 8 09-29-2007 11:06 PM
Shift gear knob Jfoofoo Cosmetic Modifications (Exterior/Interior) 9 09-11-2006 12:20 PM
