Old 05-23-2013, 11:30 AM   #1
Septembersrain
♣♀Yaris'ing♀♣
Septembersrain's Avatar
Drives: 2013 Yaris 3-Door LE ~Pearl~
Normal or not normal?
I'm new to this car (It's my first new car period) so I have a few questions:
When I have the air conditioner on, If I idle it seems to have the compressor turn on and off continuously. Normal?
When I go to stop, The car seems to shutter just a little tiny bit.
I was told this is just the engine downshifting. Normal?
After I started putting in premium gas the car seems to want to constantly get into a higher gear. Normal?
Thanks!
Don't be a drip. ◄~(¬ _¬)~
Septembersrain is offline   Reply With Quote
Old 05-23-2013, 12:52 PM   #2
Normal for the first two. Running premium gas should not make a bit of difference, so that may just be a perceived effect.
Old 05-23-2013, 02:16 PM   #3
Septembersrain
♣♀Yaris'ing♀♣
Thanks for the response, I don't want to seem paranoid.
I'm not sure if it was just subconsciously me driving faster.
I noticed it about a week after I started using that gas.
Is there anything else I should be doing while the car is in the break in period?
Old 05-24-2013, 01:47 PM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
hug it once a day. If you take it for granted, it will leave you.
-Derrick-
Old 05-24-2013, 01:53 PM   #5
nookandcrannycar
.....or if you take it for granted, it might start breaking down .
Last edited by nookandcrannycar; 05-24-2013 at 03:44 PM. Reason: sp -- = breaking -- should have had a cup of coffee before typing the post!
Old 05-24-2013, 02:50 PM   #6
Septembersrain
♣♀Yaris'ing♀♣
Haha. Oh man. I almost laughed my sugar cookie pudding out my nose.
I think I love my cars way to much, I treat them better than some people. =P
So I think I'm going for a slightly bigger size tire so I can get my Michelin Defenders again.
Do you think I'll notice a huge difference between 185/65 suggested and the stock 175/65?
Old 05-24-2013, 03:19 PM   #7
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
10mm wider and 6.5mm taller. basically you will be going slightly (and I do mean slightly) faster than what your speedometer reads. honestly I don't think it will be noticeable at all.
Old 05-27-2013, 12:50 PM   #8
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
I was concerned originally with the rough idling at a stop, but once I learned it was the engine dropping RPMs to the minimum, I was OK with it.
I have observed a slight smoothing of the idling if I slip the gear shit into N while sitting at a traffic signal.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Wheels slipping when hard lock turning - dealer says this is normal? eskiepeskie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-08-2012 08:49 PM
Smoke smell question. Is this normal? Ilovemyyaris DIY / Maintenance / Service 6 08-10-2012 02:04 PM
Transmission sounds, what is normal ? Yaris17 DIY / Maintenance / Service 3 11-20-2011 07:00 AM
How much engine vibration is normal? Frankd1 DIY / Maintenance / Service 6 10-14-2009 09:11 PM
Is This Normal? i was told its normal, but i dont think it is jthebeh DIY / Maintenance / Service 3 11-27-2006 08:46 AM
