![]() Drives: 2007 hatchback Join Date: Aug 2007
Yaris towing
Why can't a yaris tow? Everyone seems to be ragging on the guy below becaose he bought a hitch. I have a 2007 liftback lowered with 18 inch wheels. I put an the hidden hitch and rear airbags so it don't squat with a trailer. I have a 5x8 trailer and pull 2 YZ 125 dirtbikes and a 4 wheeler. The car pulls perfect. I pull in 4th gear 80 MPH with no problems. It is a little sluggish in fifth gear unless you run on flat roads then it is fine. My truck used $45.00 in gas going to the MX track and my car only uses $7.00. I guess I am stupid to just like the other guy with a hitch. Some people just don't have a clue and are scared to do something different.
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
I hauled a recliner in my LB no problems, but tried a couch and wouldn't fit so had to feed the gas monster! Definately getting a hitch and trailer by next spring and get rid if the truck. Payback wouldn't take long at all.
____________ ![]() ![]() |
![]() Drives: 2007 Yaris S Sedan (silver) Join Date: Sep 2007
Does anybody have an idea how much a motorcycle trailer might weigh? I'm hoping to use my Yaris S sedan to tow my CBR600RR sportbike to the track (it weighs about 400 pounds with no gas) and I want to keep the load as light as possible. Is this reasonable? Thanks!
![]() ![]() Drives: Polar White 2007 Yaris LB Join Date: Sep 2006
Do you think my Yaris HB could tow a jetskii?
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
You're safe up to 700 lbs. including cargo, people, and weight of the trailer. A jetski trailer (one jetski) shouldn't weight that much. In WA state, trailer titles have the weight posted, and the jetski dealer should have the weight of the jetski (the manufacturers website would have this as well.)
I am in the process of moving to a new place about 5 miles away and have a 440lb 4x7 utility trailer for my fiberglass body, 2-person dune buggy/go kart. The buggy weighs at least 300 lbs. I towed it all last night just fine. With all the weight of other stuff in the car and on the trailer I had to have been close to 1,000 lbs. I had to take it slow though because the only way to get the buggy on the trailer is to have the engine at the back, causing the trailer to wobble side to side if I went over 40mph. Yeah, you should be fine if you keep it at 700 lbs or less. I got my hitch on ebay and the seller even gives you a receiver hitch and pin (but no ball.) EDIT: I forgot to mention about wiring the harness. There was enough room to push the wires I needed into the stock wiring harness and I didn't need a heavy duty flasher. Even using regular trailer lights my blinkers work normally and I just fed the wires though under the spare tire though a groumet in the floorboard. The hidden hitch looks nice too. The only parts visible is the receiver opening and tow hook spots. |
#6 | |
![]() I figured I would be ok as long as I only tow one jetskii, but wasnt completely sure. |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
umm you may want to think about that jet ski...
a quick search of the net, and using 3 weights i got an average of over 700lbs.. jetski 700lbs. +trailer weight + weight of fuel/oil in jetski + weight of passengers/you + weight of cargo... it'll work but your pushing things...
out of respect for nutzoid, I changed my avatar. ![]() |
#8 | |
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
Towing Hitch for a Yaris | fmicle | General Yaris / Vitz Discussion | 1 | 05-16-2007 07:07 PM |
Tree 1 - Yaris 0 | gabagooo | General Yaris / Vitz Discussion | 19 | 04-25-2007 05:24 PM |
