02-18-2017, 05:30 AM | #1 |
Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
what spark plugs are you using with your current engine setting
i am using ngk iridium spark plug with minor E85 tuned engine..some are saying how we should use colder spark plugs for turbo or tuned engine etc.
higher octane = colder plugs? opinion on spark plugs? Sent from my SM-N920C using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
How to change spark plugs | mitsua | General Yaris / Vitz Discussion | 4 | 08-14-2015 09:59 AM |
Changed Spark Plugs | MyzticZ3r0 | DIY / Maintenance / Service | 4 | 11-14-2014 12:58 AM |
Bigger Spark plug? | samuraivince | Performance Modifications | 6 | 08-05-2014 04:09 PM |
spark plugs | walt101786 | DIY / Maintenance / Service | 0 | 09-24-2011 05:25 AM |
Spark Plugs | YamilR | DIY / Maintenance / Service | 2 | 09-28-2007 08:38 PM |
