10-26-2016, 04:33 AM | #1 |
Drives: e61 Join Date: Oct 2016
brake fluid
when to replace the brake fluid? how to make sure brake fluid should be replaced?
sorry for my bad English. thanks |
10-26-2016, 05:53 AM | #2 |
Drives: 08 Sedan Join Date: Oct 2008
I change mine every 2 years...
10-26-2016, 10:05 AM | #3 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
^this
No one ever wants to give a Yaris the point by... |
10-26-2016, 10:58 AM | #4 | |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
My wifes 05 Camry has 135k on it and my 09 Yaris 44k and the brake fluid has never been changed or even bled in either car without any ill effect. And while I am Casper Milquetoast driving my car my wife drives like a bat out of hell! However it certainly wouldnt hurt to change it as it might prolong the life of the brake system parts. If you have a manual transmission however that also uses brake fluid and I recommend at least a bleeding every two years, even though there is no requirement in the owners manual. The clutch gets used about ten times as much as the brakes and if air gets into the system or the fluid goes bad at the the clutch cylinder, it can result in hard shifting which might make you think there something wrong with the clutch itself.
10-26-2016, 11:17 AM | #5 | |
My '06, build date 11/2005 with close to 300,000kms on her has never been changed. In all my years of vehicle ownership, which sadly is becoming considerable, I've never replaced brake fluid for the sake of just replacing it. No issues ever. Go ahead and do it if you like. It's your time and money.
10-26-2016, 09:15 PM | #6 | |
https://www.youtube.com/watch?v=o81GjHj4z4s
10-26-2016, 11:56 PM | #7 |
Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Every two years is the generally accepted interval. I never used to believe in changing brake fluid (even as a Mechanic) until I worked for Nissan. There are some Nissan calipers that are well known to seize. At the dealership where they do brake flushes, they never have any issues (to the point the other Mechanics thought I was crazy when I asked about them). A brake flush is cheap compared to calipers, so it is cost-effective to change your brake fluid on most vehicles.
Cheers. |
10-27-2016, 01:07 AM | #8 |
All this is provided the bleeders will open without snapping off first...
10-27-2016, 01:13 AM | #9 |
Yeah. It's a good idea to crack the bleeders loose by tightening them further. Then as soon as they move, stop and then loosen them. They are far less likely to break this way (as are all bolts. Especially small ones). Even if they do break, you know they are still sealed and will not leak.
10-28-2016, 01:19 AM | #10 |
Drives: 2007 yaris 3 door Join Date: Sep 2015
change your fluid every 2 years.
brake fluid is hydroscopic; it absorbs moisture. it depends on where you live. I live in the desert climate, the humidly is usually less than 20%. even in this environment brake fluid becomes wet. brake lines are made of copper tube. the old brake fluid can slowly strip the copper down from moisture corrosion. this crud "falls" into your calipers and wears seals/pistons prematurely. the moisture can also cause damage to rubber components in the system making them weak and brittle. moisture also raises the boiling point in brake fluid. in a panic situation under heavy breaking, wet brake fluid can boil/vaporize causing loss of brake function. change your fluid. make sure your tech uses a new, sealed bottle of fluid. I've worked at a lot of shops where there is large bulk open bottles of brake fluid sitting at everyone's work area. I tell them how brake fluid works, but they say something like, "i'vebeen doing this for 20 years..." or something like that. you've been doing it wrong for 20 years more like it... change your fluid. use new, unopened fluid. smart. |
10-28-2016, 08:06 AM | #11 |
Brakes lines are made of steel not copper.
10-28-2016, 11:04 PM | #12 |
no they are not. they are called "Bundy tube." just the rubber parts that you replace with aftermarket SS are "steel." then you have different metals which is a whole different issue in itself.
if you don't trust me, do you trust Stacey David? https://www.youtube.com/watch?v=o81GjHj4z4s here is the Wikipedia on bundy tubing. even if they use the low-corrosive european tube, it still has copper to aid in bending properties. https://en.wikipedia.org/wiki/Bundy_tube |
11-02-2016, 03:30 AM | #13 | |
11-02-2016, 03:32 AM | #14 |
11-02-2016, 08:48 AM | #15 | |
I say an opened but resealed container of brake fluid will NOT absorb moisture even after three years! In a car brake fluid is NOT sealed but its debateable how much water it will absorb. A FoMoCo study found less than 1% water after seven years in its cars.
11-02-2016, 11:24 AM | #16 | |
Simply put, $5-10 worth of brake fluid every 2yrs to reduce the chances of calipers seizing is a no-brainer. |
11-02-2016, 11:36 PM | #17 | |
11-02-2016, 11:52 PM | #18 | |
it will not cause any damage, i separated the brake fluid from the car, just to check, anyway it is very cheap |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
Brake Fluid reservoir hose, is it suppose to be like this ? | Goldenyaris | DIY / Maintenance / Service | 0 | 12-15-2014 07:31 AM |
Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
Will this hold? Plastic bag vs brake fluid | lamadoo | DIY / Maintenance / Service | 7 | 04-25-2013 03:35 AM |
red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
