Old 10-11-2018, 05:33 PM   #1
boa
Drives: Toyota Yaris 2008 Sedan
Removing bolt off AC compressor clutch
Hello,
I have a 2008 1.5L automatic yaris sedan. There are bearings in the compressor pulley that have gone bad and the car makes a grinding noise. I bought a compressor clutch kit to replace the whole system. The problem is I can't remove the bolt that holds the clutch and pulley on. If I try to remove with a ratchet it just rotates the pulley with the belt. How do I get this damn thing off?
Below is a picture of the original compressor clutch and pulley.
https://ibb.co/kx62G9
Thanks for your help.
boa is offline   Reply With Quote
Old 10-12-2018, 01:35 AM   #2
B.B._07
Drives: 07 5dr
The 7mm bolt is left hand threaded so you need to turn it clockwise or to the right to loosen it. I've taken it off using a cordless 18V 1/4" impact, not really sure how you can stop it from spinning if you're using a ratchet.
Valve Cover Bolt Size help. please. 06YarisRS DIY / Maintenance / Service 1 01-02-2018 05:53 PM
Broken Control Arm Bolt Sirius-XM DIY / Maintenance / Service 4 02-29-2016 08:27 PM
Rounded bolt replacing belt thekatiel DIY / Maintenance / Service 13 09-29-2014 06:39 AM
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
