Old 02-04-2017, 08:09 PM   #1
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Upgraded 1NZ injectors
I posted this question in my own thread in the boosted section but didn't get any responses. So I thought I'd repost it here...
Anyone know the actual specs on the 1ZZFE injectors? I've heard an array of answers on the CC range.
Looking at these - both listed for the Toyota 1.8
23250-22040
vs
23250-0D050
Anyone know the difference? What are most people using when they are attempting to upgrade their current 1NZ injectors?
JustDidIt is offline   Reply With Quote
Old 02-05-2017, 12:49 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Green:
Blue:
https://monkeywrenchracing.com/produ...or-1-1zz-blue/
Not sure of the actual reason for different part numbers. Possibly spray pattern or internal resistance? Maybe just color coded to keep them separate on the production line?
Old 02-06-2017, 04:28 AM   #3
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
someone did a review & comparison:
https://bobistheoilguy.com/forums/ub...Injectors_for_
I've also switched my orange injector to the jap blue ones. I did notice they were a bit smoother on idle and better fuel consumption during highway travel
Fluxtasy is offline   Reply With Quote
Old 02-06-2017, 07:30 AM   #4
JustDidIt
JustDidIt's Avatar
Interesting.. Thx! Wonder if it really is just the spray pattern or the +5cc difference ? The green ones have more YW user reviews but this blue review intrigues me.
Old 02-06-2017, 09:06 AM   #5
Fluxtasy
feed my pet
Fluxtasy's Avatar
oh yeah my orange injector has the same nozzle pattern as the blue ones. Possibly the cc are about the same too. My mechanic did mentioned that the cycle duty are probably different.
Old 02-06-2017, 11:05 AM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I needed this info too. Thanks for the info everyone. I'll make sure to look for the blue injectors then.
Old 02-06-2017, 11:08 AM   #7
JustDidIt
JustDidIt's Avatar
How do these look? These are "flow-matched"...
http://m.ebay.com/itm/Denso-Flow-Mat...ATCHING_ACTIVE
Old 02-06-2017, 02:44 PM   #8
David C
Drives: White '07 3dr LB
Are the 1.8L injectors intended to be used in the Yaris 1.5L 1NZ engine ?
Envoyé de mon iPhone en utilisant Tapatalk
Old 02-06-2017, 04:02 PM   #9
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Very nice info! Not sure how I missed this initially in either section. I'll be upgrading now that I have a path for a turbo on my 1NR-FE.
MugenRep is offline   Reply With Quote
Old 02-06-2017, 06:40 PM   #10
JustDidIt
JustDidIt's Avatar
Intended... no. But for boosted 1NZ applications and other performance modifications, the 1ZZ injectors have shown to help performance.
Old 02-06-2017, 10:01 PM   #11
CrankyOldMan
I upgraded to the green 1ZZ injectors to keep from going lean with my Blitz supercharger. If you have a proper engine management system, you can just tune the fuel map to compensate. The Blitz comes with a really basic piggyback that just makes the ECU go into open loop mode, which just dumps a ton of fuel to ensure it's not running lean. Bigger injectors = more fuel = lower AFR under boost. Not terribly elegant, but safer than running lean and breaking things.
Old 02-06-2017, 10:05 PM   #12
David C
Thanks
Old 02-07-2017, 10:09 AM   #13
Bluevitz-rs
Just as a reminder, what's the 1NZ injectors rated at for CCs so I can make the adjustment in the FIC?
Old 02-07-2017, 10:21 AM   #14
JustDidIt
JustDidIt's Avatar
I don't have exact.. but I've read 200-210cc. It's the same part number for the 1NZFXE as it is for the 1NZFE
Old 02-09-2017, 05:38 PM   #15
Bluevitz-rs
an interesting page I found regarding the flow rate and injector response time for the 1NZ injectors. Unfortunately they don't have the 1ZZ injectors listed.
Link
Old 02-09-2017, 05:39 PM   #16
JustDidIt
JustDidIt's Avatar
Nice -
1NZ: 200cc 19lb/hr 14ohm
Old 02-09-2017, 06:16 PM   #17
Bluevitz-rs
I can't remember what I have my response time set to but I'm going to change it to about 500us. My idle seems seems to be very rich as my fuel trims are always very far into the negative area and it crank on cold starts longer than it should.
I'll report.back when I get around to it.
Old 02-09-2017, 07:57 PM   #18
Bluevitz-rs
I don't know why but I had it set to 850us. That would explain the long cranking and poor throttle response when hot. Moved it to 526us. I'll have to check my fuel trims now. Did it just before rushing out to work.
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 10:11 AM
Stock Injectors = Maybe? Big NO? maxthehax Forced Induction Forum 3 12-10-2012 05:29 PM
FS: DeatschWerks 550cc Plug/Play injectors Tamago Items for Sale by private party 4 06-27-2012 11:11 PM
2 sets 1nz fuel injectors for sale fnkngrv Items for Sale by private party 2 06-05-2012 05:35 PM
200cc Vs 240cc Fuel Injectors SL Runner Performance Modifications 2 09-07-2011 05:08 PM
