Old 09-04-2017, 04:47 PM   #1
Bony_ahmed
Drives: Toyota Yaris SEdan
Need Advice about Engine !!!!!!!!
Mine is a 07 yaris with 1.3 2nzfe. Recently engine is making intense blow by, even i got oil in the intake manifold. What should i do ? the car idles poorly, i have cleaned throttle body, maf sensor, changed spark plugs, air filter. When i put in Drive the car shakes like hell and sometimes stalls. i dont get bad mileage or drop in power, the car feels a bit off power but its very slight. I got 124k km on the odo. Local mechanics are saying i should swap for 1nzfe, What should i do....im getting confused. oh btw the engine burns oil, like i have to put 250ml every 1k km. my concerns are
Will a valve timing fix will solve it??
do i really need an engine swap ??
or is it related to any vaccum issues ?
Bony_ahmed is offline   Reply With Quote
Old 09-05-2017, 08:33 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Burns oil PCV Positive Crankcase Ventilation valve
very first thing is to check/clean/replace PCV valve.
might consider adding a catch-can to keep intake cleaner if cause isn't found and you want to keep using the motor.
Some of these cars use almost no oil at that mileage or more. But yours is less than Toyota manual allowance.
Old 09-05-2017, 09:07 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Do a compression test and see if you have a piston ring problem
Old 09-05-2017, 01:21 PM   #4
Bony_ahmed
Okay im changing the pcv tomorrow, lets see what happens. Thanx mate
Old 09-07-2017, 08:02 PM   #5
Bony_ahmed
The PCV is okay.......it seems i have a compression issue :( :(
Old 09-07-2017, 08:26 PM   #6
SirDigby
Drives: 2007 yaris 3 door
the answer is: 1NZ-FE install
Check engine light + vibration Lisbeth DIY / Maintenance / Service 12 04-05-2020 09:28 PM
Engine Delayed Start - Toyota 1NZ-FE 1.5L SL Runner General Yaris / Vitz Discussion 9 07-23-2011 03:13 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
