Old 05-26-2018, 02:22 PM   #1
zoharby
Drives: Toyota Yaris 2003, 1.3 Manual
2003 Yaris SCP12 P0500 speed error
Hi,
I own a manual 2003 Yrais (SCP12, 1.3 2SZ-FE engine).
I had all my 4 brakes replaced + regular servicing, and immediately following that the following problem started:
1. ABS yellow light lights up
2. Red circle with exclamation mark lights up
3. Speed stays at 0 Km/h
4. Odometer doesn't advance
5. ABS stops working, but otherwise drive feels 100% normal.
It started right after the service, so a good chance they messed something with some wiring... When the car is started it's sometimes OK, but after a few minutes of driving it returns.
After driving like that for a while, the yellow "check engine" light also lit up, OBD reads P0500.
Do I get it correctly - the car has 2 ABS sensors AND a separate speed sensor? Does the P0500 code indicate it's the speed sensor and not the ABS sensors?
The shop takes responsibility for now, but they haven't been able to fix it until now and I want to make sure they're in the right direction..
zoharby is offline   Reply With Quote
Old 01-31-2022, 05:27 AM   #2
Mksifa
Drives: Toyota yaris 08 5dr
fix
did you ever fix this, i have exactly the same problem
Mksifa is offline   Reply With Quote
Old 01-31-2022, 05:58 AM   #3
zoharby
Yes, they ended up solving this by replacing the ABS computer / controller (don't remember the exact name). If I recall correctly it's an electronic controller module together with the ABS pump.
They replaced it with a used one (which was still quite expensive) and it solved the problem.
Yaris sales hit new low... Kal-El Third Gen Yaris General Discussion 129 12-18-2014 01:25 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Yaris Digital Speedo Error?? jack DIY / Maintenance / Service 5 03-20-2006 05:37 AM
