Old 05-19-2013, 11:58 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
handbrake warning alarm??
anyone know if it is possible install a handbrake warning alarm to prevent driving while the handbrake is on?
caineroad is offline   Reply With Quote
Old 05-20-2013, 01:22 AM   #2
YarisSedan
YarisSedan's Avatar
Drives: 08 Yaris Sedan
I thought all yaris came with one already I found out mine had one when I was driving testing the hand brake it started beeping like crazy till it was released
Old 05-20-2013, 01:23 AM   #3
caineroad
caineroad's Avatar
No my doesn't, I have a hatchback not sedan though maybe it's diff?
Old 05-20-2013, 01:25 AM   #4
YarisSedan
YarisSedan's Avatar
My girlfriend has a 09 hb and hers has a chime too it sounds like the seat belt chime
Old 05-20-2013, 01:30 AM   #5
caineroad
caineroad's Avatar
http://www.yarisworld.com/forums/showthread.php?t=12101
Not all Yaris have the handbrake alarm. See above click.
If anyone know how to install one ? I assume just connecting the handbrake light or wire to the seat belt chime?
Old 05-20-2013, 01:46 AM   #6
Kar98
Drives: 2011 Scion tC
Your parking brake alert should be that you're not going anywhere ;)
Kar98 is offline   Reply With Quote
Old 05-20-2013, 06:12 AM   #7
The parking brake switch has one yellow wire. When the brake is up that wire gets grounded, so you can install a 12V beeper and connect its + lead to ignition switched power and its - lead to that yellow wire.
Old 05-20-2013, 07:09 AM   #8
nookandcrannycar
As one post on your link suggests, perhaps it is a pre 08 thing. Mine doesn't have one either.
Old 05-20-2013, 09:58 AM   #9
caineroad
caineroad's Avatar
Looks simple, but if I do that, it seems like the beeper will sound even when the car is not moving (ignition on, but not driving, in Park mode)
Is it possible to make something that only beeps when car is driving?
Old 05-20-2013, 10:30 AM   #10
That is correct.
It would be possible to make one that only beeps when the car is moving, but that would take a bit of extra electronics to do so.
Old 05-20-2013, 10:32 AM   #11
caineroad
caineroad's Avatar
That is correct.
Not sure why some Yaris have this fitted but some don't.
Similarly the seat belt chime only sound when the speed is over 20km/h(equivalent to xx miles), if it is easier, how possible is it to hook up the handbrake wire to seat belt chime?
I would really like to have one that works only when the car is moving, can you briefly explain where i have to connect to make this work, I will try my best to figure it out myself.
Thanks
Old 05-20-2013, 11:53 AM   #12
Thanks
I think it may have just been a feature added in 07 or 08. If that is the case, changing the cluster to a newer might make it work (although the ebrake switch is an input to the body ECU, rather than the cluster).
Bridging the seatbelt and ebrake would be way more difficult than adding a motion based signal to the ebrake.
If you want to experiment with a beeper, tie the - side to the yellow wire on the ebrake switch and the + side to the pink wire on the ignition switch connector.
Old 05-20-2013, 01:52 PM   #13
caineroad
caineroad's Avatar
Yea..not feeling like changing the cluster, i like my 2006 version.
But I will try experiment with the beeper like you suggested, thanks
Old 05-20-2013, 02:28 PM   #14
caineroad
caineroad's Avatar
I kind of found a solution, it may work ok, but not what it ideally for
I will bridge a motion sensor with delay timer... let's see if this will work well
Old 05-20-2013, 02:40 PM   #15
You would be better off with an accelerometer. The Yaris vibrates more when stationary than when it is moving.
Old 05-20-2013, 02:42 PM   #16
caineroad
caineroad's Avatar
oops, i was gonna say motion, like a regular household motion sensor that works with 12V and adjustable sensor and timer. If I can find something smaller I would also use that.
Accelerometer is good idea, let me see what ebay has to offer.
Old 05-20-2013, 02:50 PM   #17
I could actually make you a device that works off the VSS (speed sensor) wire. My Demetricifier (which lets a km cluster work as a Mile one) interprets that signal, so driving a beeper instead of manipulating that signal would be very easy.
Old 05-20-2013, 02:53 PM   #18
caineroad
caineroad's Avatar
Sure, it might actually be a lot easier at my end, if it is not too expensive, Im really just looking for an economical way to do this little beeper. Thanks
Factory Alarm on my '08 Liftback is Too Sensitive! alex_melodymaker In Car Entertainment + Electronics (audio / video / alarm) 9 06-07-2011 03:21 PM
Alarm Wiring Advise Needed Lil Abner In Car Entertainment + Electronics (audio / video / alarm) 14 09-26-2010 10:11 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 01:49 PM
Rant! Damn car alarm installers, trying to rip me off!!!! W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 18 11-21-2006 09:18 PM
