Old 12-27-2014, 06:52 PM   #1
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Automatic A/C: Ambient sensor airflow?
Hi,
I'm gathering parts to give my HB an automatic A/C, sadly some things are a bit confusing.
As I have no service manuals, I have had a look at an EPC drawing which showed an air duct going from the ambient sensor to the upper section of the air box - some cm behind the flaps.
However, there's a piece of plastic not closer specified on the drawing which connects duct and air box.
As the air box is quite expensive here, I want to get away by simply connecting the sensor and the air box with a small tube, but two questions arise:
1)What is this sensor supposed to measure?
If it's the mixed air being about to enter the cabin, it seems legit.
If it's the actual cabin air temperature, wouldn't it be better to connect it to a small pc fan or the intake side of the blower?
2)Is that piece of plastic some kind of valve?
I drive, therefore I am.
dj92 is offline   Reply With Quote
Old 12-27-2014, 07:07 PM   #2
The ambient temp sensor measures the cabin air temp. I believe that the tube simply creates a suction (venturi effect) so that the ambient sensor gets air from the cabin, rather than from the dash.
And, that piece is just a flexible plastic tube.
I have also done a couple of the conversions, so I can help if you have any issues.
Old 12-27-2014, 07:18 PM   #3
dj92
Embracing Curves
dj92's Avatar
Thanks for your answer
OK, another issue is the solar sensor - also pretty expensive here (80€ or so) and hard to get, so I feel tempted to test my electronic skills
It is drawn like a diode, so I would assume that it is a photo diode.
Have you made any experiments with usual photo diodes (dark vs. light current etc.) or did you always use the original sensor?
Old 12-27-2014, 07:58 PM   #4
The OEM sensors are used on many other Toyotas, so they can be found inexpensively. They are just photo diodes, but I didn't test the characteristics. I may have on hand. If I do I will check it out shortly.
I checked and do not have one, but the service manual for the Prius (which uses the same sensor) confirms it is a photo diode. The only specs it lists is that the resistance of the photo diode will be an open circuit in dark and not an open circuit in light.
Old 01-02-2015, 10:00 AM   #5
dj92
Embracing Curves
dj92's Avatar
Now I have got the parts and successfully soldered white LEDs into the control assembly, but I'm already running into problems.
Following the wiring diagram, I thought the servos to have included some LIN electronics or the like, so it could be on a 3 wire bus.
Instead, each one has 5 pins, 3 of them lead to some kind of rotary encoder and the other ones lead directly to the motor.
Before I start analyzing the PCB:
Do you have any hints to which pins these servos connect to?
Sadly, I was not able to get the connectors or even a wiring harness.
Old 01-02-2015, 10:58 PM   #6
I have always gotten them with the harness between the servos and the ECU, so I have never had to worry about that pinout. Let me see what I can find, as the service manual does not even show that info.
Old 01-04-2015, 02:06 PM   #7
dj92
Embracing Curves
dj92's Avatar
I have had a look at some drawings and have come to the conclusion that the servo controllers are a part of the rather small servo harness.
I am not a 100% sure, but it seems to cost about 160€.
That's a lot, however, the alternative would be building 3 servo controllers which would be cost effective, but take a bunch of weeks.
The even bigger problem is, the 4800 baud serial data on the bus pin does not change as I e.g. change where the air goes out according to the display.
Possibly, this is because the A/C is missing the other devices on the can bus, but the weather ATM is too cold for me to spend some hours outside in my car, so I hesitate to pull the original A/Cs fuses and hook it up to the bus.
Techstream requires the ECU to be present on the bus, so I can not do anything with it up to now.
My automatic A/C came from a european TS which is almost entirely JDM and has an air ionizer which I did not find on any wiring diagram - did you have any mysterious wires on the connectors you bought?
Old 01-04-2015, 09:08 PM   #8
My automatic A/C came from a european TS which is almostentirely JDM and has an air ionizer which I did not find on any wiring diagram - did you have any mysterious wires on the connectors you bought?
Everything made sense wiring-wise on what I had. I never had one with the ionizer.
Old 01-05-2015, 07:43 PM   #9
dj92
Embracing Curves
dj92's Avatar
I poked into it with Techstream and found out that it in fact misses the servo controllers - this single-wire bus is bi-directional.
You don't have only the harness with the controllers inside to sell, do you?
Old 01-09-2015, 03:53 PM   #10
Astroman
Modded Moderator
Astroman's Avatar
This was posted in the wrong section of the forum, moved it to the correct one.
JDM Automatic A/C Conversion Demonstration CTScott DIY / Maintenance / Service 7 04-02-2022 05:44 PM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
