Squeaky Transmission? 5MT
I have a strange occurrence where my Transmission squeaks just the slightest little bit when going into and out of gear...mostly 3rd and 4th. I originally thought it was my brakes or someone elses brakes. It doesn't happen every time though either. Can anyone tell me what is going on?
lube this part. if you look under the hood at your linkage move this part side to side and lube. white lithium grease in the spray can works great.
![]() ![]() ![]() Drives: '07 Yaris S Sedan M5 Join Date: Jul 2007
Thanks kou! I've learned to live with the squeak but hopefully this DIY will kill it. Any brand recommendation for a "white lithium grease in the spray can"?
no special brand its just easier with the can,it should come with a little red straw for the nozzle. spray in the gap between the two parts.it moves side to side when going 3-4.i changed the pic slightly so you can see where to spray exactly.
Wow, so the yellow part? and the squeak will be gone?
spray in the two little yellow marks inside the circle and the noise should go away.
thanks much! I appreciate it!
anytime.
![]() ![]() ![]() ![]() Drives: Yaris YR Join Date: Oct 2008
Haha i had this problem, i actually got it fixed this morning too by the Toyota Service Mechanic, he sprayed some stuff on that part to. Now it's gone. :D
![]() Mods: 17x7 ANZ Tazer Wheels with 215/40/17 Marangoni Tyres | AFE Air Intake System | NST Short Shifter Kit | NST Shifter Cable Bushing Kit | NST 10% Underdrive Crank Pulley | Pedders Sports Springs | Custom 2inch Cat-Back Walker Muffler with 2.5inch Xforce Twin Stainless Steel Tip | RS Side Skirts | RS Euro Spoiler | YRX Front Lip Spoiler | TRD Style Front Grill | 12mm Rear Hub Spacers | Ultra Racing 23mm Rear Sway Bar |
I went ahead and bought some of the before mentioned lube from advance auto for about $3. I sprayed some on each linkage just to make sure. There is no squeak anymore. You may need to take out the air box and battery tray to be able to lube everything up...unless you are Mr. Fantastic. ^^ Great advice! I may spray this on some suspension bushings as well...
Lurker supreme!
Thanks for the post... this has been squeaking on mine for the last couple months. F the dealership... I'll do it!
2006 Red Blitzed RS 5-door |
haha.. mine is doing that since 2+ years ago... and is still doing it after 53000km. ^^
my personal toyota mechanic told me to take the shift linkage out and grease the hell out of it. but i got lazy and never did it. haha but thanks, i'll shoot some grease to that part see how it goes. |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Now i see where the battery GND is!
You may wanna to try a dry moly lube so you don't collect any sand if you live in areas where the roads are sanded ![]() Sonja's Bro |
DIY done. Squeak is killed!
Alright! I didn't know that it was this widespread!
First time DIYer
Thread Tools | |
Display Modes | |
Urgent! How to use auto transmission? | hans_fh | General Yaris / Vitz Discussion | 55 | 04-16-2010 01:45 PM |
2009 Yaris "S" - no 5MT Hatchback? | Latka | New YARIS Purchase Forum | 21 | 11-07-2008 04:16 PM |
New transmission at 8.5K miles! | d2dailly | DIY / Maintenance / Service | 17 | 09-22-2007 11:41 AM |
Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
Synthetic oil for transmission | mrrock | DIY / Maintenance / Service | 7 | 04-26-2007 03:51 PM |
