#55 |
![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
#56 |
boydstir
hay guys my 08 lb has 45000 miles on it i had the cat changed by toyota at least 10,000 miles ago and i still get the shitty smell when i stand on it for a block straight or more and if i roll the throttle to the floor without getting the auto trand to kick down this has done this from day one when i got purchased the car from the dealer . can someone re flash the ecu in the car to stop this problem i here its dumping to much fuel in it and the smell is the cat doing its job someone help me please this is getting old right along with the piss poor millage i get off and on also i burn chevron premium or shell and texeco fuels thanks oh i run momo 15" wheels with 195-55-15 tires with more air in them than i really like due to the harsh ride
Last edited by pennyracer; 02-28-2009 at 12:43 PM. Reason: left a few details out |
#57 |
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
are you normally running at any specific speed? and what gear are you normally in?
#58 |
![]() ![]() ![]() Drives: '09 Yaris LB Join Date: Dec 2008
just to update. I have been getting 24-25 city mileage lately. This is REAL city driving. like half traffic half moving sometimes.
i have been slightly more gentle in between lights...i suffer from split personalities (one race car driver, and one conservationist) I think my low (around 20) was due to snow, extremely cold temps, lots of short drives, excessive acceleration, and MAYBE the fact that its brand new, although this theory is questionable. i now have 3500 miles and im torn between changing the oil ASAP or waiting til the recommended period. I know folks have thoughts on that, so i wont even ask. i may just do 4000..seems like a happy medium. |
#59 |
boydstir
i have a automatic trans and i dont drive it like i stolled it very often :)
#60 |
REDyaris
Drives: 2008 Sedan Join Date: Feb 2009
great gas mileage
Two weeks ago i picked up my 2008 Yaris sedan -- first tank 36.8, second tank 38.1, third tank 40.2 mpg. I drive gently and haven't tried any hypermiling techniques. I drive about 40 percent highway, 60 percent around town.
#61 | |
ekodrvr
#62 |
toyota
i bet you its the calculator...give us ur conversion.....what unit are you using??
#63 |
Yes- I fit in it.
I just figured out my first tank.... 37.62 mpg. I guess I can't complain too much coming from about 20mpg.
I'm surprised it doesn't have a pull-start ! |
#64 |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
wow...20s is WAY off...i have 17s with way oversized tread...much wider and taller than factory tires...i do mostly city driving, and i drive like i stole it half the time...and i havent ever gone below mid 30's.
if you are actually getting 20mpg i would wager the check engine light is on or should be on, cause that lil bugger is running pig rich!
#65 |
I'd be crying if I were getting 20; my 29 (city) to 36 (hwy) is bad enough when I read about others supposedly getting 42-50 without even trying. It's rather disappointing.
Have you solved the mystery yet??? |
#66 |
![]() Drives: 2008 Toyota Yaris, automatic Join Date: Oct 2008
I've never got 39mpg. 35 at the very best.
I have an auto coup 08. City driving I'm in the mid 20's. Highway I'm at low 30s. I drive at about 75mph on the highway. I'm disappointed. Is this normal or should I take it in and complain? |
#67 |
ekodrvr
what is your speed in town? average?
#68 | |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
During warm up the engine runs richer and a higher RPM. For the first two miles in warm weather you won't go above 20 MPG. Cold weather would make this worst. Add to that a lot of short trips where the engine never fully warms up and you get the kind of mileage you're getting. It takes three mile in SoCal to get the engine to operating temperature and then your MPG goes to the 30's. Hang in there! ![]() |
#69 | |
![]() Drives: 2008 Yaris Join Date: Mar 2009
I actually did my first oil change around 2k. Kinda the old school way. I think when I rebuilt my motor for my 77 TA I changed the oil after 10hrs. Also.....all I run is Mobil 1 Synthetic with the factory filters. Never before did I do this till I bought new. |
#70 |
Forgot to add that the worst FE I have gotten is 26 while delivering pizzas and the best so far is 35.....I think.
#71 | |
The Hated One
with that being said, on alot of high performance engines i have helped build, we have fired them up, and changed the oil after running for 10 or so minutes, changed the oil, then, ran oil in it for a while during a hard run(if its in the car, take it out and run it through the RPM ranges) and then change it again. using synthetic oil on ANY engine near the break in point is not a good idea, the molecules in most synthetics are so fine, that sometimes a proper ring seat is never achived because there isnt enough friction. as time goes on, more and more auto manufactures claim their engines do not need break in time, and that synthetics are ok from the start. my personal recommendation for breaking a new car in... run the factory oil in it for a day. drive the car through all the RPM ranges, even close to redline. dont push the car hard up hills or be abusive, but never granny it. run it through all the ranges at a steady pace, and never keep the RPM's the same for a extended period(if you are commuting, bounce between 3rd, 4th, and 5th if its a manual). change the oil with a high quality petrolium based motor oil of the vehicles recommended weight. run that oil for a few hundred miles and replace it with the same stuff. if you plan to run synthetics, start running a blend no sooner than 5,000 miles. for the first few thousand miles, change the oil every 3k, sooner if you are doing city driving, lots of idleing, or start up-shut off driving. after at least 10k, start with synthetics. you can start stretching the oil change intervals out if you have a high grade synthetic. personally, i go: 100 miles or less(regular oil change) 300-500 miles(regular oil change) 3000 miles (regular oil change) 6000 miles (synthetic blend oil change) every 3k a syn blend oil change(i do mostly city driving). this is a VERY excessive and overly carefull break in process. you dont have to do it, you dont really need to do it. but, if you want to do things perfectly and you want to keep the car till it dies, its a few more bucks on oil changes, but its the obsessive way to do it. p.s. forgot to mention. the side affect to piston rings not seating is oil consumption at later milage. most imports make it alot of miles before oil burning regardless of how they were maintained...im just obsessive compulsive on the proper break in stuff,lol.
#72 |
![]() ![]() Drives: Yaris 5 door Liftback Join Date: Oct 2008
Gentlemen, how are you able to determine exactly how much gasoline was used up to do a mileage test? I was never clear on how someone obtains exact numbers to the tenth like the type posted here in this thread and other places. How do you know you used 1.6 gallons, 4.3 gallons, etc.?
Thread Tools | |
Display Modes | |
-Mileage Thread- -Log your mileage, year, model, color, any problems here... | Kal-El | DIY / Maintenance / Service | 322 | 07-20-2016 10:07 AM |
Sedan better gas mileage than LB? 5 month gas chart included | flint_mica_manual | General Yaris / Vitz Discussion | 24 | 03-09-2009 08:24 AM |
The Official Having A Bad Day Thread. | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 7 | 11-15-2008 08:38 AM |
Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 12:32 AM |
Fuel / Temp / Mileage Gauge - Special LED Readings? | bigsky2 | General Yaris / Vitz Discussion | 3 | 05-31-2006 09:04 AM |
