Old 04-23-2009, 01:46 PM   #1
maxgil05
Drives: Vios
Is LSD Automatic & Manual Same?
Is the LSD automatic same as manual, i mean can LSD for manual fit in an automatic car?
maxgil05 is offline   Reply With Quote
Old 04-23-2009, 09:57 PM   #2
orangepeels
orangepeels's Avatar
Drives: 2008 3 door LB
Yes. A limited slip differential...goes in the differential.
orangepeels is offline   Reply With Quote
Old 04-23-2009, 10:06 PM   #3
severous01
most GM apps are different due to a different carrier....not as in cell phone carrier or cable provider....talkin about the thing the ring and spiders mount to. the smaller series carriers are different than larger and is usually split by a 3.23 or a 3.73 ratio in RWD applications. so, if you had a 3.23 and wanted 3.73 you'd need the .73 carrier....or if you had a 2.73 n wanted 3.23 you already have the .23 carrier and would only need the ring/pinion setup...
i have no experience in FWD setups cuz most ppl just order a beffy trans to fix the prob. and if you look up the info i believe you can use the same trans as the celica/TC and you can get your 6-spd easy since the GTS is all over the junk yards now.
Old 04-24-2009, 10:21 AM   #4
coheed
Drives: 08 BB LB
IDK, a LSD automatic runs off of rpms or a computer. Manuals are all gear driven. I dont know if they will be compatable.
Old 04-24-2009, 10:57 AM   #5
severous01
final drive is a ring and pinion just like a differential or rear. only difference is the 'driveshaft' is actually an axle-shaft or half shaft...
Vitz 2001 Automatic Instruction Manual madar General Yaris / Vitz Discussion 3 02-14-2013 01:49 PM
Automatic to Manual converts... any regrets?? maramaralula New YARIS Purchase Forum 22 07-31-2011 10:06 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Change automatic to Manual Blenjar General Yaris / Vitz Discussion 11 06-14-2007 06:02 AM
Manual vs. Automatic ?? YarisBlazer General Yaris / Vitz Discussion 12 08-13-2006 07:14 PM
