07-15-2009, 11:28 PM | #127 | |
Drives: '07 Yaris Sedan 'S' Join Date: Dec 2008
07-15-2009, 11:35 PM | #128 |
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
hi!!!
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com |
07-16-2009, 11:24 AM | #129 |
Just a Herbicidal maniac.
Drives: 2008 Yaris S Sedan Flint Mica Join Date: Oct 2008
No problem. I think the hardest part was to figure out a way to hold the eyelids so you can paint them and let them dry. You only need to get to the top and edges, the bottom can be left un-painted. I ended up using papertowel tubes, no papertowels on it of course, and taped them to the underside of the eyelids. Once they are secure, find a spot that you can set the tube down (standing it upright) and paint. Maybe stick a screwdriver into the ground and put the tube over it. Start the paint process by holding down the button on the spray paint can before you get to the eyelid and continue with the paint until after the eyelid. Hold the can about 8 - 10" away and move the spray can back and forth smoothly. Don't try to cover it in one or two passes. Be patient and follow the directions on the cans. Many light coats are better than 2 or 3 thick coats. Follow the same process for the clear coat, making sure the actual paint has had plenty of time to cure. Again, check the clear coat spray can for when it's safe to spray the clear. You can do it!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace. |
07-16-2009, 01:09 PM | #130 |
07-16-2009, 01:11 PM | #131 | |
oh shit i hope i didnt get the wrong color. its the exact same as those big pics right above. well, the one on my profile.i know theres a darker silver almost grey. thats not me.
07-16-2009, 01:18 PM | #132 |
so< treyz... what the hell is a bayou yaris? lol
07-16-2009, 07:58 PM | #133 |
~ ambient one ~
AMBIENTLIFESTYLE
07-16-2009, 10:16 PM | #134 |
oh. duh, sorry. thats like me saying 2007 streak yaris sedan. lol
07-25-2009, 08:43 PM | #135 |
Drives: Toyota Yaris Sedan Join Date: Jun 2006
heres mine i thought i would do something a little different
07 Yaris Sedan TRD Axle back exhuast, Weapon R Dragon Intake, NST underdrive crank pulley, Megan Racing Headers, amber fog lights, 15'' Flat Black Rota Slipstreams, TRD lowering springs |
07-25-2009, 08:58 PM | #136 |
Drives: 2009 Meteorite 3dr Join Date: Jul 2009
interesting for sure. How does that look with the lights on?.. no bad shadows or anything?
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
07-26-2009, 12:50 AM | #137 |
~ ambient one ~
Use a blow dryer next time to strech the vinyl out so you don't have the folds/crinkles. You will need to pull off the headlights to be successful in that.
AMBIENTLIFESTYLE
07-26-2009, 04:39 AM | #138 | |
and its industrial window tint but its only temporary till i buy some better materials
07-26-2009, 10:19 PM | #139 |
Any update?
07-28-2009, 08:43 AM | #140 |
~ ambient one ~
Yeah, in this this case, Vinyl would be the best case, but you need to see what's translucent. But the tint should have contoured better with the heat though no?
AMBIENTLIFESTYLE
07-28-2009, 11:34 AM | #141 |
Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
When they offer 09 LB headlights without the yeller side markers I'll get the eyelids, otherwise it just accenuates the problem.
07-29-2009, 11:27 AM | #142 |
~ ambient one ~
What do you mean? I have an 09 liftback with the eyelids carrried over from the 07.
AMBIENTLIFESTYLE
07-29-2009, 11:46 AM | #143 |
07-29-2009, 11:54 AM | #144 |
Slowy getting there
^ Most states require that amber reflector. Toyota put them in the head light because if they put it anywhere else then it would have been "BAD" styling. If you take out amber reflector you will probably get ticketed for it alot. But if it really bothers you that much then bake your head light, pull them apart, and remove the reflector.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
OFFICIAL Yaris SEDAN thread | SimmZ | Photo-Video-Media Gallery | 1705 | 01-13-2020 11:20 AM |
The Official "Bambo the Yarisworld Traveler" thread (V1) | nemesisz | Off-topic / Other Cars / Everything else Discussions | 3 | 11-08-2008 10:24 PM |
I can't seem to find the thread with the pics of the '08 brochure, help? | Jailbird | General Yaris / Vitz Discussion | 1 | 09-11-2007 08:40 PM |
Sterio Pics Thread | BlueFlash | Off-topic / Other Cars / Everything else Discussions | 0 | 06-08-2007 04:55 PM |
