07-19-2009, 09:54 PM | #1 |
Drives: Yaris 2008 Sedan Join Date: Jun 2009
removed spare tire, but now the board is bending
I removed the spare tire in order to reduce the weight of the car in an attempt to reduce my fuel consumption. However, the board is beginning to bend because there is no longer a tire supporting it underneath. Is there anything I can buy that is light weight to take the place of the spare tire?
Perhaps a lightweight compartment for emergency supplies that is shaped like a tire? |
07-19-2009, 10:03 PM | #2 | |
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles" Join Date: Apr 2009
2009 Absolutely Red LB. "Bubbles" |
07-19-2009, 10:25 PM | #3 |
boydstir
ya forget everything else i just got two 10" subs the hell with the rest :) wieght for milage :( speakers for sound :))
07-19-2009, 10:41 PM | #4 | |
Drives: 2008 Yaris Meteorite LB Join Date: Feb 2009
07-19-2009, 10:51 PM | #5 |
Thanks! I will consider putting the tire back into the truck as I don't have a pump or sealant.
EasyDriver, thanks for the tip! |
07-20-2009, 01:16 AM | #6 |
Need More Mods!
styrofoam?
Giggity, Giggity |
07-20-2009, 02:02 AM | #7 |
Drives: 2005 Ford Focus Join Date: Aug 2007
Road side assistance. And on long drives more then 100 miles, throw the spare back in, so you can keep moving on the road trip or whatever.
07-20-2009, 07:17 AM | #8 |
Half a Bubble Off Plumb
If you ever use sealant, you're going to be buying a new TPMS monitor for that wheel. And what a mess it is to clean out, anyway! Put that spare back in!
07-20-2009, 10:25 AM | #9 |
Start another Oil Thread!
pick up some high density foam and make a plug :)
07-20-2009, 10:30 AM | #10 |
Drives: yaris 08 sedan Join Date: Oct 2008
Throw out the board and while you're at it i'm sure the carpet weighs a pound or two and as you dont have a spare in the car eliminate the jack and lug nut wrench,remove the hub caps if you dont have alloy wheels and if no one ever sits in the back seats,toss em.
Any one else got ideas on how gotayaris08 can save more weight? |
07-20-2009, 10:35 AM | #11 |
engine and transmission weigh around 300lbs. remove them! you could cut a hole in the floorboard where the pedals are now and use your feet. since the fuel tank is no longer needed, you can remove it as well, that'll drop at least 100lbs there.
07-20-2009, 11:34 AM | #12 |
Don't know about gotayaris08, but the driver of my Yaris could stand to lose some weight.
07-20-2009, 11:43 AM | #13 |
Drives: 07 Yaris sedan Join Date: Jun 2007
Long time ago, I started replacing the usual fiberboard spare tire covers with Mahogany plywood; it is cheap (doorskin), very light, shapes with a Stanley knife, and with 1/8" thick foam tape, is soundless. I have yet to have one sag, warp, or change shape, in ~40 years. If it needs to be stronger, just glue a couple of strips of 1x2 across underneath it, and it will hold a fair amount of weight.
07-20-2009, 11:54 AM | #14 |
Audio Junky
take out the back seat.. that'll net you about 2mpg... the spare... maybe .25, and the front seat is about 1mpg..... at least thats what it appeared to be when I stripped my car of everything cept the dash & head liner.
07-20-2009, 12:44 PM | #15 |
Drives: Big Yellow Join Date: May 2009
I understand that relatively anything can break on your car, but they put spare tires on them for a reason.
It's a pretty common thing and it happens to everyone, road debris is just a fact of life. Why would you want to be sitting there waiting for someone else to get you going again when you can be back on the road in less than 20 minutes? Like someone else said, if you want to save on weight, lose the back seat. I ran my short wheel base Jeep that way for years (not for weight but for trunk space). You can always put it back in when you need it. |
07-22-2009, 06:18 PM | #16 |
ellenbetty
Drives: 2 2007 Yaris 3 door liftback Join Date: Nov 2008
Nice to know. But it will be years before I have my 2 Yarises are paid off. Loan rules forbids doing any thing to reduce the resale value of the vehicle. I do not have space to store the back seat. It has been 5+ years since I had any one sit in my back seat. I hate those space saver tires. The only thing those space saver tires are good for is to drive to the nearest tire store. Plus I will bet the space saver tire will need to be replaced before my 2 Yarises wear out. I hate the idea of spending money to replace a space saver tire.
08-05-2009, 12:56 PM | #17 |
Thats what junk yards are for!
10 Bucks and ya got a new space saver and the wheel!! |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Water in Spare Tire Well | Violin | DIY / Maintenance / Service | 10 | 01-30-2015 05:22 AM |
tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
The thread with the single, hidden sub over spare tire? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 07-17-2009 01:21 AM |
screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 04:46 PM |
The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
