Old 09-23-2009, 04:33 PM   #55
Liltoaster
Drives: 05 Echo H/B
Originally Posted by ROCKLAND TOYOTA View Post
so a nitrous kit takes almost 2 seconds off your time on a stock 1.5?
That is correct, I went from 18.03 to 14.98 with my setup :)
Liltoaster is offline   Reply With Quote
Old 09-23-2009, 05:19 PM   #56
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
You were running higher than 50hp shot for sure...
If you did a 75hp shot you got balls! props for that!
I'm helping a friend installing a NX wet kit on his Yaris on the next couple of weeks. But we will use 35hp nozzles for the street and 50hp nozzles for the track only... we will use some high octane fuel on the 50hp runs... just for extra safety...
Old 09-23-2009, 05:24 PM   #57
I'll have times on Oct 31.
Old 09-23-2009, 05:32 PM   #58
CASTREX
CASTREX's Avatar
1/8 mile times or the real deal???
What mods are you planning for the track??
Tire compound and size?? Suspension set up? come on we want more info!!
You better get her low in the 12's....
Old 09-23-2009, 07:14 PM   #59
real deal 1/4 mile @ fontana.
http://www.autoclubspeedway.com/
You know all my engine mods, but I will be trying some drag slicks I got from Art IF they fit over my brakes. I'll get them out and measure them up tomorrow. Probably need spacers.
My suspension is:
Silk Road coilovers
TRD motor mounts
BeatRush trans mount
UR rear underbrace
Tanabe front strut brace
UR 23mm rear sway bar (like that will matter, LOL)
Old 09-23-2009, 08:43 PM   #60
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Make sure you turn up the dampening on you rear shocks all the way and put your rear tires at max PSI to try and keep weight transfer to a minimum. Have you been working on your launches?
Old 09-23-2009, 08:57 PM   #61
frownonfun
frownonfun's Avatar
subscribed
Old 09-24-2009, 01:42 PM   #62
CASTREX
CASTREX's Avatar
My suspension is:
Silk Road coilovers
TRD motor mounts
UR rear underbrace
You need to make them fit..!!! If not get others that fit... or get rid of the front BBK. Like you will need that on the track! Taking your car w/o a proper set torsion tires will be like not going at all. Is a most!!
Is important to dial the right pressure for the drag slicks. I'm sure Art can give you a few pointers as he has experience with the box.
Front: just high enough not to rub the tires. Stiffness Probably some where in the middle. Front suspension should allow for some travel but have good dampening to prevent bounce.
Rear: as high as the silkroads allow and full stiff. Over inflated rear tires...
Leave the rear under braces and sway bar at home!!
Go to the local strip to practice some launches!
Oh and please.... HD video!!!!
Old 09-24-2009, 02:18 PM   #63
I don't have a BBK - all else duly noted, thanks!
Old 09-25-2009, 03:13 AM   #64
Astroman
Modded Moderator
Astroman's Avatar
Come on guys, slips!
Old 09-26-2009, 03:45 AM   #65
ruimond
Drives: Yaris YR
17.4sec 1/4 Mile. Thought a S/C Yaris would be quicker then that. Haha. Hopefully you do better next time you go with less wheel hop.
Old 09-26-2009, 04:04 AM   #66
Hey Mike, did you lower your front tires' psi? I forgot to do that too, and I had a lot of wheel hop too. I need to repost my slips one of these days...but I have to find them first.
Old 09-26-2009, 04:34 AM   #67
Nice. Yeah, I ended up beating only two cars the night I went to the strip, a Ford Ranger and a Nova (driver "fell asleep" at the tree, I think)
I was running 42 psi that night...horrible. hahahahaha.
Old 09-26-2009, 02:06 PM   #68
shinlee
shinlee's Avatar
Drives: 07 liftback
I ran a 16.36 after weight reduction, and a 16.56 fully loaded, including the spare tire. God, I can't believe someone remembers that, lol. That was almost 2 years ago ><
I'm glad to see people going sub 15 in these cars though, before I left for the army, that was all the talk!!!
shinlee is offline   Reply With Quote
Old 09-28-2009, 08:41 AM   #69
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
was that stock or with bolt ons?
Old 09-28-2009, 11:18 AM   #70
Astroman
Modded Moderator
Astroman's Avatar
Originally Posted by camelll View Post
Yeah was hoping it would be better, what can you expect from a autobox.
How about a 16.9 from my autobox, NA. I lowered my pressure to 26-28psi on stock wheels/tires in the front. You should get better times that way.
P.S. Thanks for posting your slips!!
Old 09-28-2009, 11:50 AM   #71
ROCKLAND TOYOTA
TRIM HUNTER
TIMESLIP and with what bolt-ons?
Old 09-28-2009, 12:45 PM   #72
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
17s!? ahhh. Oahu needs a track
OFFICIAL Yaris SEDAN thread SimmZ Photo-Video-Media Gallery 1705 01-13-2020 11:20 AM
Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! TRD_Yaris General Yaris / Vitz Discussion 183 02-01-2017 12:18 PM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Official bitch about gas price thread flint_mica_manual General Yaris / Vitz Discussion 61 05-24-2007 09:53 PM
