04-27-2010, 04:36 PM | #1 |
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
With the 3.5 final drive, the engine would be far too low in the revs when cruising at 60 mph and probably use more fuel because of the lack of power available at those revs.
04-27-2010, 04:45 PM | #2 | |
Drives: Paseo Join Date: Apr 2010
Plus if 3.5 is too low for you. You can get a final drive from a 4 door Echo c150 with a F/D of 3.850. |
04-27-2010, 04:52 PM | #3 |
By ending up with taller gearing in each gear, all you do is make the car into a slug (more so). You lose the "close ratio" benefits of the C160 box.
Peak torque is developed between 4200 and 4400 rpm (depending on engine) so ideally, they are the revs you want to be doing while cruising for max economy. |
Tags |
6 speed, conversion, gearbox, transmission |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 467 | 10-18-2022 10:20 AM |
DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
