Old 04-04-2009, 09:33 PM   #1
jimmydie
Drives: 07 lb
Sound when making a left turn (a water flow sound)
Hi,
I have begun noticing a sound that sounds like water flowing over some pebbles when I turn left. My wife has a fountain that pumps water across this slate, and it sounds very similar to that, and when I am coming out of my turn it sounds a bit more like a pouring water from one cup to another.
So imagine I'm turning left.
1 second into it I hear the water fountain sound for about the duration of the turn.
As I pull out of the turn I hear the water pouring sound (really quick). and than nothing after that.
I have notice that the car is smelling a bit more like mildew. I pushed up a plastic rod into the ac drain (about 5") and it didn't seem to be clogged. Does that drain need to be cleared beyond 5 inches (13 cm)
The sound does not happen when I am at a dead stop and turn the wheel.
I'm assuming that the sound and the increased smell may be related. I don't like to assume, because it makes an ass ... well you know...
Any ideas?
Best,
J
jimmydie is offline   Reply With Quote
Old 04-04-2009, 11:34 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
sounds like you got water in your air con , and the drain tube is probably
blocked as well.
Old 04-04-2009, 11:36 PM   #3
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
Check the spare tire area for water.
FunctionSpec is offline   Reply With Quote
Old 04-04-2009, 11:49 PM   #4
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
look under the seats for a loose water bottle? lol I dunno I'm just thinking of other things that haven't been mentioned yet....
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-05-2009, 12:03 AM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
but worth the check all the same
Old 06-17-2013, 11:56 AM   #6
staks
Drives: 2008 Yaris
I saw this post was made a few years ago. I am having this exact same problem. Has anyone been able to figure out what the cause of the issue?
Let me know what you found out. Thank!
staks is offline   Reply With Quote
Old 06-17-2013, 12:14 PM   #7
Yes - There are many threads on it, including this one: www.yarisworld.com/forums/showthread.php?t=6053
Old 06-20-2013, 02:07 AM   #8
JohnnyMalice
Drives: 2007 Toyota Yaris 4 door sedan
Yea I have that problem too, when I start to hear it Ill pull over, lift up the carpet slightly under the dash, you will see a black hose (kinda looks like a big bendy straw. all I do is squeeze and "milk" the hose a few times and the water will come out. Not really a big deal just do it before you have a katrina flood scene in the pass area.
JohnnyMalice is offline   Reply With Quote
Old 06-20-2013, 02:01 PM   #9
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Did you tighten all your bulkheads?
-Type 07 FFL-
My odometer 03/11
Old 06-20-2013, 05:35 PM   #10
Chuck G
Drives: 2010 Yaris Sedan
Doing mine this weekend!
Yaris idles loudly at red lights and when making sharp turn ebowers83 DIY / Maintenance / Service 36 02-24-2009 05:03 PM
