07-31-2013, 08:37 AM | #91 |
Drives: Yaris MY2012 - 1ND-TV Join Date: Jun 2013
Is it worth trying to move to Terminal 1 and 2 of the 4-pin connector at position 1 and 2 of the 10-pin connector? or is in vain? still will not go anything? The blue wire is the ground wire and do not know where to put it if put in place the terminal 1 of the 4-pin plug.
07-31-2013, 10:17 AM | #92 | |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
07-31-2013, 10:21 AM | #93 | |
07-31-2013, 11:27 AM | #94 |
Connector 1? or two, or three ...... ? I think the connector one you mean but I want to call you. Right?
07-31-2013, 11:34 AM | #95 |
You do not have the wiring diagram for 1.4 d4d? Although I know that the same engine Auris 1.4 D4D has cruise control, I hope someone will hear us and we may find a solution in the future, I just have to have patience.
07-31-2013, 12:24 PM | #96 |
It is connector 1 that we need to look at. I do have the D4D wiring diagrams, where the "engine control" one does not show cruise control, whereby the wiring diagrams for the 1.33L gas engine does. I don't have the wiring diagrams for the Auris, but I do see in the parts catalog that it uses a different ECM.
07-31-2013, 12:48 PM | #97 |
Thanks a lot for your help CTScott.
08-02-2013, 12:29 PM | #98 |
Drives: 2012 Yaris Join Date: Aug 2013
CTScott,
I am new to this forum. My daughter in Indiana just purchased a 2012 Yaris Sedan without cruise control. I noticed from the pictures she sent, that the cluster is mounted in the center of the dash vs behing the steering wheel as I am seeing in the pictures in this thread. I am guessing that Toyota did a mid-year refresh of the vehicle in 2012 and that she has the older version. I have two questions... 1) Can I add OEM cruise to her car using your instructions? 2) If so, which directions do I use. The ones for 2009-2011 or the ones for 2012? I have added OEM cruise to another daughters 2010 Cobalt. This looks much easier than that. Thanks, Fred |
08-02-2013, 01:07 PM | #99 | |
Hi Fred, Sedans did not get an update in 2012 as liftbacks did, so for your daughter's car the my 2009-2011 directions are the ones you will follow.
08-09-2013, 05:31 AM | #100 | |
Drives: MR2 GT Turbo Join Date: Oct 2012
Nic MR2 GT Turbo Supra GT35R 6spd. |
08-09-2013, 06:12 AM | #101 |
The pin that goes into the spring clips has a groove in it that the spring clip latches onto, so you are trying to open the legs on the clip to release it from the groove.
10-07-2013, 09:34 PM | #102 |
Drives: 13 yaris Join Date: Oct 2013
How do you do, it is called takumu. It has ridden on Japanese use of 12 models. There is no cruise control in vitz of Japanese use, and I am troubled by it. It did not operate, even if it post-installed the cruise control switch. If it investigates, there is no wiring of a spiral cable to the point. Who has a wiring diagram of the cruise control of yaris of 12 models? Or please let me know wiring to a computer. Thank you for your consideration.
10-07-2013, 09:46 PM | #103 | |
On the ones that do have it, Pin 60 of ECM connector A72 is where one wire of the stalk connects to and the other wire connects to chassis ground.
10-07-2013, 10:06 PM | #104 |
Mr. CTScott, thank you. My car is 1 KR-FE engine. Somehow, the form of the connector of A70 was different. It was connector-shaped [ of the same engine computer as yaris(es) from 2006 to 2011 ]. The wiring which is already different is stuck in the wiring place of the cruise control of 2011 models. It was troubled.
10-13-2013, 06:31 PM | #105 |
hi CTScott,
Are you still selling anymore of your kits? I've brought a rostra kit from amazon and the instructions are confusing. I've followed everything up to the ECM part of the instruction. I have a 2012 Yaris 5D LE. How do i determine whether my car has "CLUTCH ECM HARNESS" or not? Where the heck is the "ENGINE COMPARTMENT ON THE PASSENGER SIDE FIREWALL" Any help would be greatly appreciated |
10-13-2013, 07:01 PM | #106 | |
My kits are still for sale and for 3rd gens I also stock the little cover for the side of the steering wheel, so no drilling is even required.
10-13-2013, 07:56 PM | #107 |
good to know i've wasted ALOT of time opening everything trying to figure that part out. Everything about their stupid instruction seems wrong.
1)"For 2012 Yaris: Using a "Torx" Driver, push in the 3 snap rings to disengage it from the 3 pins" - After checking out this site, i realized a flat head screw driver should do the trick. 2)The template cut didn't make sense - 1.5 inch hole saw is not needed. It was simpler to just use a razor to cut out a rectangle for the piece. As for the 1/4 pilot hole, i never understood what it was for. 3) If you're right about the "BLACK ECM CONNECTOR C20 IN THE ENGINE COMPARTMENT ON THE PASSENGER SIDE FIREWALL", that's more wrong info from them for page 6 (steps 1-3) Their instructions are the worst (http://www.rostra.com/manuals/250-1836_Form5370A.pdf). This was suppose to be specifically for the 2012 yaris. I see that you have also mentioned similar instructions within the forum matching theirs on page 7 (steps 5 to 7). Do i still need to do this? BTW, can you PM me on how to buy from you? Last edited by spammenot66; 10-13-2013 at 08:10 PM. |
10-13-2013, 09:30 PM | #108 | |
The page 7 info is completely wrong for a 2012. The 2012+ are all prewired. The only thing that would have to be done is to install and plug in (connector is present) the clutch switch for a manual transmission Yaris. So, for 2012+ just install the stalk and you're done for an auto. For a manual, also install the clutch switch. All wiring is present, so it is just a matter of plugging them in.
Tags |
cruise control. 2012 |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
