#91 |
Drives: yaris 2013 Join Date: Apr 2016
Hello!
I have manual yaris 2013 with 1.4 diesel engine. What parts do I need for the cruise to get it work? Thanks |
#92 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
For the diesel, your only option is an aftermarket complete system.
#93 |
![]() Drives: 07 Toyota Yaris Base Join Date: Jan 2016
Lots of good info here, thanks for having it as a resource CTScott! I've learned a lot reading through the threads about adding OEM cruise.
I'd like to purchase a wiring kit and indicator from you for my 07 LB AT, tried sending you a PM but looks like there's a minimum post requirement. Sent you a PM, if duplicate then I apologize in advance.
~Erik~ Last edited by ScarabEpic22; 05-25-2016 at 07:59 PM. |
#94 | |
#95 |
Drives: Yaris 2014 Join Date: May 2016
Cruise Control Installed!
Scott,
Thanks for the cruise control kit for my 2014 Yaris L. Just as you said, it was easy to install, really plug and play. Took about 20 mins. and the wiring you included for stalk and horn wire made connections simple. If I can do it anyone can! ![]() Anita (Mikey's wifey) |
#96 | |
Newbie
Drives: 2008 Yaris 3 door Join Date: Jun 2016
Cruise Control Kit 08 Liftback (3door) Manual
I am looking for a Cruise Control Kit 08 for a Liftback (3door) Manual. I am open to either style (stock or switch). I am new to the forum so i don't believe it will let me send a PM. Do you have anything available?
#97 |
![]() Drives: 2007 Yaris Sedan Join Date: Mar 2009
Hi, new here and just wanted to say thank you to CTScott for this awesome DIY! Installed it in my 09 liftback within an hour and it is working flawlessly. Pulled the parts from a 08 Yaris at the junk yard and, believe it or not, it had that same DIY done to it by the previous owner! Not bad at all, especially since it only cost me 6$!
#98 |
![]() ![]() Drives: 2015 yaris L Join Date: Jun 2016
Would a 2015 five door L automatic U.S. Yaris only need the stalk and wiring to plug in to clock spring and horn? If so do you have parts for this?
#99 |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
The Series 3 cruise control installaion is very easy. See http://www.yarisworld.com/forums/showthread.php?t=37205 for details.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#100 |
![]() Drives: Yaris Join Date: Jun 2016
I have a question about my Yaris. I bought it in Las Vegas and I want to make sure that the ECU will tolerate the cruise control. It's a 2007 model. It says that it was manufactured in Japan, but it's a Toyota and that's where they're all manufactured, right? Just want to clarify that this method will work before I start rounding up the parts.
#101 | |
#102 |
Thanks! I will follow your pdf instructions and let you know how it goes! Appreciate it!
#103 |
cruise for 2015 U.S. Yaris L, french built
#104 |
Drives: 2010 yaris sedan Join Date: Jul 2016
Hi Scott I Sent a pm . Thanks
#105 |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
Hi Scott, if I was to use a switch and LED to do a basic setup, could you pinpoint the essential wires ? Would a lighted 4 way switch work as a CC stalk and on/off indicator or do the CC indicator module would still be needed to act as a smart relay ? I have a '07 3dr LB, Canada. PM me the details if possible.
Thanks |
#106 |
![]() Drives: 2008 Toyota Yaris Join Date: Jul 2016
Just used your guide to install a stalk and wiring. Worked great! The only thing I ran into was that I read the part about the indicator as "Yes: You'll need the indicator kit" or "No: You won't need the indicator kit" so I was a little disappointed when no light came on in the cluster but so happy to have cruise control on this car! Might have to get the indicator kit sometime just to have it in there.
#107 |
Well, we're on our first road trip with the cruise control and it hasn't been completely smooth. The on/off button doesn't seem to work reliably the first time after starting the car. After you get it to come on the first time, it works great.
Is this just a problem with the switch/stalk i got? Is the control just a resistor ladder and could i just install a momentary switch with a resistor across the leads? Sent from my LG-H811 using Tapatalk |
#108 | |
Thread Tools | |
Display Modes | |
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
