10-25-2018, 12:13 PM | #1 |
Drives: 2007 yaris HB Join Date: Mar 2016
Is this a half decent caliper?
My front driver side is sticking and heating up the wheel.I replaced the pins and lubed when I changed the pads and rotor this summer.
Instead of pissing around I figured just get a whole new unit.This one seems really chea$. I Not sure if I already burned out the bearing(Those are new aswell) https://www.napacanada.com/en/p/CPR2...earchIndex=App |
10-25-2018, 12:29 PM | #2 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
Wait, you want to replace the whole caliper because the pins were seized which you have addressed and fixed?
No one ever wants to give a Yaris the point by... |
10-25-2018, 12:31 PM | #3 |
10-25-2018, 01:35 PM | #4 |
Well it's a remanufactured caliper so should be no different than what you've got. Me, I'd first just check and re-lube the sliding pins. If however the piston itself is seized, then maybe I'd invest in a caliper replacement.
10-25-2018, 01:40 PM | #5 | |
I will take a look,but will most likely replace the whole unit.I dont want to be pissing about mid winter with stuck brakes.I see its a reconditioned unit.Perhaps I should find a brand new one,and possibly do both side while at it. |
10-25-2018, 02:34 PM | #6 |
I agree w/ Wee. Find out why sliders are sticking, unless it is a seized piston but that's unlikely.
What grease did you use? I have never found any brake grease to be as good as purple ceramic permatex. It's not cheap but much cheaper then a new caliper
10-25-2018, 03:08 PM | #7 | |
10-25-2018, 03:33 PM | #8 |
10-25-2018, 04:13 PM | #9 | |
10-25-2018, 04:49 PM | #10 |
Did you try rotating the hub when you had everything apart?
10-25-2018, 04:55 PM | #11 | |
I have never had a wheel bearing give zero symptoms before failure.There is no play and zero noise. From what I can see though the outer pad seems tight against rotor,and the inner pad that moves in kinda lopsided.To explain better the pad retracts but mostly on the top part of pad? If it happens to be a bearing I will replace the hub and bearing as a unit.The price is not much more for entire unit and i wont need a mechanic to press bearing in. |
10-25-2018, 07:01 PM | #12 |
I didn't know that there was a full assembly for the front hub bearing?
Sounds like your sliders are seized to me
10-25-2018, 07:05 PM | #13 |
I installed new caliper.I can see the caliper retract when someone pushes brake.Looks to be a bad wheel bearing most likely.thing is the bearing has no play and is completly silent.Not all that unheard of for a bad bearing,but not common.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
front caliper pin tunring wont' snug | nambi_ | DIY / Maintenance / Service | 2 | 09-07-2018 07:34 PM |
Passenger side caliper loose... | baseballfan416 | DIY / Maintenance / Service | 5 | 08-17-2016 10:35 PM |
Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
My Yaris with a lil' Half 'N' Half | The Architect | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 05-18-2009 01:36 PM |
Yaris half mask? | kimona | Cosmetic Modifications (Exterior/Interior) | 1 | 06-14-2007 07:10 PM |
