Old 12-23-2006, 11:32 AM   #19
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
Originally Posted by acrbill View Post
Once you are moving there really is no reason to go back into first.
what about when you're racing?
Old 12-23-2006, 01:16 PM   #20
acrbill
Drives: Polar White Hatch
Then there really is no reason for it. Most of the time you try and shift as seldom as possible.
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 12-23-2006, 01:19 PM   #21
Tamago
Tamago's Avatar
Drives: ZZW30
you've clearly never autocrossed.
Old 12-23-2006, 01:53 PM   #22
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
Originally Posted by Katana View Post
The 1.3lt engine model has a lot of torque and it isi easy to start on 2nd gear.
I don't know why, but I had a 1.3L Ford and it also had significantly more torque in the low end than the 1.5 Yaris. I drove the Ford uphill in Swiss Alps loaded with 5 adults on very steep and curvy roads, it pulled so easily.
hystria is offline   Reply With Quote
Old 12-23-2006, 01:59 PM   #23
acrbill
Thats exactly what I am talking about. If its a tight short course you try and stay in 2rd, if its a bit more open you might have to shift into 3rd. Thats why some 6 spd cars are at a disadvantage on certain courses.
You sure as hell don't want to drop back into 1st gear in an auto-x.
Old 12-23-2006, 07:20 PM   #24
Pars
Drives: 07 Yaris Liftback
Originally Posted by El Jefe View Post
to me it sounds like the cables of the shifter need to be lubed, toyotas use 2 cables to shift gears, when those become dry they can make some weird noises, just take it in to the dealer if you can and show them
What causes the shift cable to become dry? And is if difficult to lubricate it yourself?
Pars is offline   Reply With Quote
Old 12-23-2006, 07:34 PM   #25
Tamago
Tamago's Avatar
Drives: ZZW30
you've never been in a tight chicago box then.
Old 12-23-2006, 08:48 PM   #26
acrbill
I have never dropped back into 1st with my Neon. Perhaps the lack of trq. in the yaris will make it a necessity. I guess I will see once the season starts up.
Old 12-23-2006, 08:50 PM   #27
Tamago
Tamago's Avatar
Drives: ZZW30
guess so :)
Old 12-24-2006, 03:52 AM   #28
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
It has to do with the rpms that the torque comes out.In the 1.3lt Yaris, it has more torque at about 2500-4500 rpms.
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 09:55 AM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
Rear shock absorbers problem Yaris PTY-507 Central and South America 1 10-16-2006 04:07 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
no tach= problem for newb? BrownNBubbly General Yaris / Vitz Discussion 19 05-18-2006 02:16 PM
