Old 04-01-2010, 03:20 PM   #1
eht13
Drives: .
Exhaust tips
I found the two different exhaust tips shown below on a Toyota dealer's site... one in the "accessories catalog" that all dealers seem to have in common, and the other in a "parts store". They look a little different, but they seem to essentially be the same thing, but for a very different price. Does anyone know about either of these? And does anyone know how the quality and installation of these would compare to the exhaust tips available at Wal-mart, for example? I've seen people mention those tips on here. Thanks.
eht13 is offline   Reply With Quote
Old 04-01-2010, 04:35 PM   #2
DARK AGE 53
Drives: 2009 Yaris Onyx
The top one looks like what came on my Onyx, the bottom one looks like it goes on a larger dia. pipe plus it also looks like it's a weld on type. Here's a cheaper place to buy the top tip, http://www.trdsparks.com/displaypart...&parts_id=2137 .
DARK AGE 53 is offline   Reply With Quote
Old 04-01-2010, 04:39 PM   #3
severous01
walmart...8 bux.
or autozone for 10. they all screw on, or you can cut off the screw parts and have it welded, but the weld area will corrode and rust.
Old 04-01-2010, 04:53 PM   #4
MadMax
MadMax's Avatar
^^ This.
The $12 one at Walmart not only looks good, but actually improves the exhaust tone a little. Search the forum, there was a thread on it to include a video...
Cheers! M2
Old 04-01-2010, 05:41 PM   #5
eht13
Drives: .
Thanks everyone. Those two I showed should be the same diameter; they are both noted as being for the Yaris specifically. As far as the screw on type, either these or the Wal-mart ones... they just have two screws, at a 90 degree angle to each other, that you screw in against the existing pipe to create enough tension that it is held securely? And they are secure enough that way? One I saw would have the tips of the actual screws touching the pipe, while the other had the screws pushing a flat head (a rectangular moving piece) against the pipe.
Old 04-01-2010, 07:48 PM   #6
DARK AGE 53
not mine.
Old 04-02-2010, 09:44 AM   #7
bitz767
Drives: 2010 Black Manual 3 door
the one i picked up from autozone had 2 screws on it with teeth, but i got out to my car and realized that it wouldnt fit with the screws, so i took the screws out and it fit snugly onto the pipe. Once i got home, i used a rubber mallet to put it on securely and it hasnt come moved at all after a month
bitz767 is offline   Reply With Quote
Old 04-02-2010, 11:13 AM   #8
eht13
Drives: .
Originally Posted by DARK AGE 53 View Post
not mine.
Thanks... that looks like a sturdier design. The ones I saw at Wal-mart had the other design I described, with two screws going in against the existing pipe, with either the screw tips or a rectangular head pushed by the screws holding against it. I guess your design is what they are referring to with the "single bolt-on" description.
Also, I noticed that the exhaust pipe on the sedan (maybe hatchback too) has the last portion of the pipe at a downward angle, not parallel with the ground or the car. So these tips are at that angle too, or do they somehow adjust for it? In the pictures I've seen they look more flush and parallel than that.
Old 04-02-2010, 01:26 PM   #9
DARK AGE 53
my tip is what comes on the Onyx edtion, I'll remove it to see if the exhaust pipe has been cut.
Old 04-02-2010, 01:41 PM   #10
DARK AGE 53
looks like stock end to me.
Old 04-02-2010, 02:53 PM   #11
eht13
Drives: .
Thanks for checking and showing the pics. That is what the end of mine looks like too... hard to tell there if the slight downward angle is the same or not though.
Old 04-03-2010, 01:09 AM   #12
Dec24th
Drives: '10 Yaris 3 door HB
the Walmart exhaust tips will do your Yaris well. I got mine for $4 on clearance. It screws on very easily and it won't break your wallet. The screws need to be tight to secure it on.
Get the Walmart one, it will give you the same result as the $50 tip.
Dec24th is offline   Reply With Quote
Old 04-03-2010, 11:27 PM   #13
eht13
Drives: .
^ Thanks.
Must be THIS thread... thanks. THIS thread too, haha.
Old 04-03-2010, 11:53 PM   #14
RedRide
RedRide's Avatar
FWIW......I got the WalMart tip last july and it is starting to rust.
Old 04-03-2010, 11:59 PM   #15
eht13
Drives: .
Interesting... one of the ones that says it is stainless steel?
Old 04-04-2010, 12:06 AM   #16
IsLNdbOi
IsLNdbOi's Avatar
The one I got from PepBoys (same brand as the WalMart one, but square tip instead of circle or oval) started rusting too.
exhaust tips what do you think? 06silveryaris Performance Modifications 32 08-01-2009 01:22 AM
Exhaust Tips DOMAV General Yaris / Vitz Discussion 4 07-08-2009 11:42 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
What's your opinion on Exhaust Tips? custom Lftback Cosmetic Modifications (Exterior/Interior) 47 11-19-2008 12:12 PM
Exhaust tips Sedan Liftback tomjasz Cosmetic Modifications (Exterior/Interior) 25 08-14-2006 06:05 PM
