![]() ![]() ![]() ![]() ![]() ![]() ULTIMATE |
Airbag/Seatbelt Sensor Bypass Module
Designed and built in the USA by our own CTScott The OCS Bypass Module emulates the function of the four seat frame mounted sensors allowing arming/disarming of the passenger airbag by reporting that the seat is either unoccupied (when the switch is in the “OFF” position) or occupied (when the switch is in the “ON” position) by an adult (150+ lbs). The OCS Bypass module also allows use of a harness, in place of the OEM passenger seat belt by emulating the function of the passenger seat belt buckle sensor. If the optional wire is connected to the Occupant Detection Computer the module will report that the seat belt buckle is latched (when the switch is in the “ON” position) and unlatched (when the switch is in the “OFF” position). $56.95. Comes with complete instructions - FREE shipping! http://shop.microimageonline.com/Air...dule-OCSBM.htm
| Airbag light won't turn off | dubgil | DIY / Maintenance / Service | 83 | 05-18-2013 10:20 AM |
| Replace airbag in my 2007 Yaris | uglyducklin | DIY / Maintenance / Service | 2 | 01-12-2011 03:53 PM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 08:20 AM |
| Passenger Airbag Question | RedStickHam | DIY / Maintenance / Service | 5 | 08-08-2010 10:43 PM |
| WTB: Driver Airbag, Airbag Control Module, Upper Tie Bar | opdmize | Willing to Buy by private party | 1 | 03-19-2010 01:01 AM |
