![]() ![]() Drives: Yaris sedan Join Date: Jun 2010
Hello, Does the Yaris come with a crush washer on the drain plug from the factory? I did 2 oil changes so far on the Yaris, and a few on a 02 Corolla, guess what, both of them don't have a crush washer! Maybe the guy at the shop just tossed them away? Should i get one for my next oil change? Thanks.
Yes, it comes with one. You can buy them for about $.50. I always replace mine at every oil change.
#3 | |
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
boydstir
thats what im thinking any leaks i know when i did the auto trans drain i tryed using the old crush washer and it dripped slightly so now i have extra drain plug and washers just in case for oil and trans
Mine doesn't have one. No leaks either.
They tend to stick to the oil pan and not stay with the plug. I always have to tap them off the bottom of the pan with a screwdriver or wrench. They are an aluminum washer sandwiched between grey paper.
Never take eyes off opponent - Bruce Lee |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
should be included in oil filter if there's one on the car. mine has a rubber gasket i think. idk...it's only been 6 months since my last oil change
I changed my oil yesterday, and i saw there was a silver washer permanently attached onto the black oil pan. Right by the drain hole. Anyone else noticed it?
Drives: 2008 yaris Join Date: Jul 2012
mine has the same thing..was worried that there was no gasket..but that must be it.
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Same here. I did the first oil change on my 2012 and was searching the oil pan for the washer when it was stuck on the pan!
I just left it stuck there and put the plug back in. No leak.
| Tranny Fluid/Oil Drain Plug Questions | WankelsRevenge | DIY / Maintenance / Service | 3 | 03-08-2011 05:01 PM |
| Review: Magneticdrainplug.com's magnetic drain plug | schleppy | DIY / Maintenance / Service | 13 | 04-21-2009 12:04 AM |
| Oil drain plug gasket question | schleppy | DIY / Maintenance / Service | 7 | 04-17-2009 05:35 AM |
| motor oil drain plug washer | xpeteyjtx | DIY / Maintenance / Service | 13 | 12-30-2008 02:27 PM |
