Old 06-19-2011, 05:57 PM   #235
p123456789
Drives: 07 lb jeep tj
Am I the only one who thinks the yaris a/c works very well even down here the florida humidity?
p123456789 is offline   Reply With Quote
Old 06-23-2011, 08:52 PM   #236
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Send a message via Skype™ to Black_griffin6
Hey guys, I just bought the stuff to do this with.
I got the insulation and the zip-ties, and now I need to get the tape to reflect the heat.
I've got a few concerns though...
What if moisture gets under the insulation? The pipe won't rust will it? I'm rather worried about the long-term affects.
I'll give it a whirl anyway seeing as how nobody has said anything bad about it.
Black_griffin6 is offline   Reply With Quote
Old 10-15-2011, 01:29 PM   #237
poorsh2
Drives: 2008 yaris hb
ss Zip ties
I put the insulation on with ss "zip ties" you can get them at harbor freight
poorsh2 is offline   Reply With Quote
Old 06-28-2012, 05:06 PM   #238
LugNut
LugNut's Avatar
Drives: 2007 2DR Liftback
Cool It does help!
I too did this modification, a couple of months ago, in response to the very weak AC performance. Thanks for the idea!
I did the entire suction line, from the firewall to the compressor. I mostly used insulation for 1/2 in. copper tubing (one stick, from Home Depot), but also a little for 3/4 in. on some bigger sections. For even bigger parts, like the in-line accumulator, I had to wrap with two split pieces.
There's definitely more cooling capacity, but at the cost of fuel economy. Before I could barely detect a difference in lugging of the engine with the compressor engaged. But now there's a big AC load on the engine.
On warm days I now get 40F air, but today, at 105F outside, I only got 52F. And still definitely not enough total cooling capacity even though the supply air is much cooler than before. But much better than no AC at all!
In response to some questions/concerns by prior posters, yes, there should be insulation on this line (but do at your own risk). My RAV4 does have some factory-installed insulation for part of the run. And if you have a split-system AC at your house/apartment, look at its large line ("suction"/"vapor") -- it hopefully still has its black foam insulation. But the small line ("pressure"/"liquid") definitely should not have insulation -- the refrigerant is still very hot coming out of the condenser, so losing more heat on its way to the expansion valve is a good thing.
Also, yes there is danger in doing this mod. First, lots of sharp edges, etc. under the hood! But there's also a danger that if the system is overcharged, or the AC is operated when too cold outside, that "liquid" refrigerant could enter the compressor and damage/destroy it. The accumulator is there to help prevent this, and I almost left it uninsulated. But I've done AC work, so repairing a system isn't that scary to me, and this insulation mod was intriguing. Glad I did it, so far. You, though, might want to have your refrigerant pressures checked immediately after doing this mod.
2007 Yaris Liftback, auto, highly optioned, 1F8 Meteorite Metallic
Modifications completed:
Cabin air filter; Cruise control; AC suction line insulation; Customized/fitted sunshade; Subwoofer; Speakers; Window tint; Seat tilt; two-seater/lightweight rear deck
Wanted: Cheap but excellent factory alloy wheels and spoiler
LugNut is offline   Reply With Quote
Old 06-29-2012, 07:02 PM   #239
Em_
Drives: 2007 Yaris
i tried it and it melted , it's a fire hazard from my point of view even with reflecting tape,
if the car burns the insurance won't cover
the only solution would be exhaust insulating fabric
Em_ is offline   Reply With Quote
Old 06-30-2012, 11:00 PM   #240
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Is this true? I can't see how insulating a line would actually affect the load of the compressor. It should simply be reducing the lost cooling in the pipes.
teddy is offline   Reply With Quote
Old 07-01-2012, 09:20 AM   #241
PatrickJohnson
Drives: 2008 Yaris LB
Then you did it wrong. I've had mine on for years now, with no issues.
PatrickJohnson is offline   Reply With Quote
Old 07-01-2012, 10:09 AM   #242
Bluevitz-rs
Living the 1NZ-6spd dream
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
here's an example of what not to use and what you should've used...
http://www.thesolarshop.eu/acatalog/...nsulation.html
Old 07-01-2012, 12:06 PM   #243
CoryM
Drives: 2009 5-door, 5-speed
First time seeing this topic. My concern would be that you are removing some of the engineering that was so carefully put into the A/C system. By this I mean that the liquid coming out of the compressor needs to evaporate completely. Some of which is expected to be done in that line (not where you want it, but they probably allow for the loss). If it stays liquid the compressor tries to do the impossible and compress the incompressible (liquid). This would explain the extra load noticed when the a/c is on. Basically the compressor pistons are in mild hydraulic lock (and hating it). Compressor life will be reduced.
Probably less likely in ridiculously hot/arid places where the evaporator will deal with it. But in humid areas, or more sane temperatures, you may run into this.
Cheers.
Old 07-02-2012, 06:15 PM   #244
schume
Drives: 2010 Yaris LB
You could be right and they might have engineered the A/C system to compensate for the loss due to uninsulated suction lines. I insulated my line and I only use the A/C when it's hot, so I'm sure I'm getting good evaporation. Maybe if I ran the A/C on cold below a certain temperature, I could start having problems.
The accumulator is there to prevent any liquid from reentering the compressor, but I guess we'll wait and see if there are a lot of A/C failures reported in the future :)
schume is offline   Reply With Quote
Old 07-03-2012, 12:35 PM   #245
CoryM
Do you have the a/c disabled during defrost?
As I said, I am not certain that you would end up w/ liquid. It's certainly possible, and hearing that guys are noticing more load on the engine makes it seem more probable.
Cheers.
Old 07-05-2012, 06:20 PM   #246
RedRide
RedRide's Avatar
Drives: '09 Yaris 2d HB
One must consider that the AC sys is designed to work under all extremes of ambient temps.
So, I don't see how adding a bit of insulation to simulate lower ambient temps will be detrimental.
Old 07-06-2012, 04:53 PM   #247
LugNut
LugNut's Avatar
Thumbs up Mine ain't melting
i tried it and it melted ...
105F here today, and just got back from a drive. 41F air. Insulation still in original shape. I don't know what went wrong with yours -- maybe (seriously!) lower temperature materials are sold up there?
Old 07-07-2012, 05:06 PM   #248
schume
Oh yeah! I hated that "feature" and was happy to disable it :)
I agree and I personally don't think it's a big deal either (or else I wouldn't have done the mod)
Old 07-11-2012, 03:18 PM   #249
swidd
Drives: Yaris HB
I've had mine insulated for 3 years or something now, and left it on during cold season, and have never restricted my use of A/C when cold outside. No problems at all, and the high temperature resistant tape holds up nicely.
swidd is offline   Reply With Quote
Old 08-13-2012, 03:50 AM   #250
yours_falsely
yours_falsely's Avatar
Drives: 2008 Yaris sedan
So now that some time has passed since it's first been tried, what I'm taking from this is that there don't seem to be any long term negative effects. Correct?
yours_falsely is offline   Reply With Quote
Old 08-13-2012, 11:40 AM   #251
PatrickJohnson
I'm at 2 or 3 years, and no problems here.
Old 04-20-2013, 07:17 PM   #252
yarisitis
yarisitis's Avatar
For those of you who first did this mod in 2009, how's it holding up? Any negative effects on the AC system? Foam melting?
yarisitis is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 34 09-23-2012 11:57 AM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 62 07-12-2012 11:28 AM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 45 05-26-2012 03:12 AM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 35 08-17-2009 04:58 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 03:56 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
