11-02-2013, 06:38 PM | #1 |
Yoshi 2.0
Drives: 2007 Manual Sedan Join Date: Jun 2013
Boot behind front wheel?
I was troubleshooting something, and I found the culprit..but I don't know what the exact nomenclature is. What is this item called, or what p/n is it?
11-02-2013, 06:58 PM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
That is the CV joint boot. You can replace the boot alone, but typically once they tear and dirt gets into the grease the joint gets damaged, so rather than going through the effort of pulling the axle to replace just the boot, one typically replaces the entire axle.
11-02-2013, 07:00 PM | #3 |
Yoshi 2.0
Thanks for the reply, I'll search for parts!!
11-02-2013, 09:31 PM | #4 |
Which side do you need? I have a perfect drivers side one on hand.
11-03-2013, 08:11 AM | #5 |
Yoshi 2.0
I need the drivers side. Should fit the sedan too right?
11-03-2013, 10:14 AM | #6 |
Yes. Sedan is the same. I could do $40 + shipping if you are interested.
11-03-2013, 01:57 PM | #7 |
Yoshi 2.0
12-07-2013, 02:08 PM | #8 |
Yoshi 2.0
CTScott: I just got around to looking more closely at the axleshaft, as I have some free time coming up to put it in. Correct me as needed, but this is not for an ABS Yaris? I'm not seeing the reluctor ring. Is it possible to remove the ring from the old shaft and put it on the new one?
12-07-2013, 06:00 PM | #9 | |
12-07-2013, 07:52 PM | #10 |
Yoshi 2.0
So where is the ABS Sensor getting the reading from, within the hub?
12-07-2013, 10:53 PM | #11 |
Correct. The sensor is at the end of the cable and the rotor for it is within the hub.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Massive inside wheel spin + outside wheel fender rub | CrankyOldMan | Tracking, Racing, Auto-X Forum | 8 | 06-04-2013 08:57 PM |
The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
Resistance/rubbing On Wheel During Sharp Turns? | tasha | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 05-11-2010 04:25 PM |
