Old 12-30-2013, 10:42 PM   #1
Rodger Wilco
Drives: 2010 Yaris
Newbie Question on OIL CHANGES
I know that this question has probably been asked but I cant find it so here goes:
I just bought a used 2010 Yaris with 17,000 miles on it. I have driven it less than 200 miles when the "oil light" started flashing. I have no idea what to buy.
Should I go SYNTHETIC or CONVECTIONAL, or BLEND?
What type of FILTER?
The owners manual merely says 5W-30 and make sure it is API SM...
...Well that gives me a lot of choices.
The previous owner used Mobil 1. I read that if you change oil types it will cause some of the seals to leak.
Is the synthetic thing a waste of money or a good investment? And what about the filter?
What are you guys using and why?
Thanks in advance.
Rodger Wilco is offline   Reply With Quote
Old 12-30-2013, 10:51 PM   #2
Yaristeve
Drives: 3-door hatch
This is debated all the time. It's your money. One consideration is how often do you change your oil? 3k ~4k? Synthetic is probabaly a waste. 10k? Synthetic may be good insurance.
I always use factory. Buy them in bulk online and they are almost as cheap as aftermarket.
I use Castrol GTX, every 4k miles.
Story is if you go from dino to synthetic, it may cause leaks but I've never heard of anything the other way around.
Again, will depend on who you ask.
Online prices are so cheap, why not use factory?
Old 12-30-2013, 10:55 PM   #3
JustPassinThru
Drives: No more Yaris
Thanks in advance.
I have used Mobil 1 in my 2009. I seemed to develop some lifter noise at idle (maybe not related) but no functional problems.
The potential payoffs of synoil (prevention of sludge and better cold start-up lubrication) seem to make up for the added cost. Preventive maintenance, is money spent to keep things right. Doing it halfway makes no sense.
Seals I wouldn't worry about. The oil-consumption issue comes from rings that, in the past, wouldn't seat with synoil in a new engine. I believe that issue has been resolved; with a used car, it's not an issue. It's broken in properly or it's not; you can't re-break-in an engine.
I'd stick with Mobil 1.
JustPassinThru is offline   Reply With Quote
Old 12-30-2013, 10:58 PM   #4
I use Napa 5W-30 synthetic (which is relabeled Valvoline) and it is about the same price as name brand non-synthetic.
+1 on the bulk OEM filters.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Question about oil filter... soup1207 DIY / Maintenance / Service 15 05-24-2013 12:25 PM
Question about a changing oil level Goose DIY / Maintenance / Service 3 11-02-2010 10:32 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
