Old 10-04-2014, 12:45 AM   #1
WRX
Drives: 2012 YarisLE 2014Lexusct200hF
MPG and PSI what's yours?
I have just recently realized that an increase in psi helps my handling and my mpgs. 185/55/15 on Konig feathers TRD shocks springs an rear sway. Ran my tires at 28 psi for a cush ride got 23 mpg city. Per each tank. Now at 34 psi all around and mpgs 27 city and I can corner a lot faster/ firmer. Continental tires 44 psi max rated. Just wondering what others got with different tire sizes etc. Freeway idk my figures I do mostly city driving. My driving style is spirited.
WRX is offline   Reply With Quote
Old 10-04-2014, 03:35 AM   #2
nookandcrannycar
I used to run 38-40 PSI, but lowered to the Toyoita spec 32 PSI last year. I now average a bit over 40 MPG and the higher PSI level I used to run was only a very slight bit above that.
Old 10-04-2014, 09:31 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
28psi is low..
Old 10-04-2014, 02:49 PM   #4
bronsin
bronsin's Avatar
35 psi and ~36 mpg never drive more than six miles. MPG will be lower in winter at least in NJ.
Old 10-04-2014, 03:18 PM   #5
beaker
Drives: 07 Yaris 3 door
Running 17 inch DE Edge wheels with 205/40/17 Atrezzo tires. Ran 32 psi for a couple of tank fulls at first when I put the new wheels on, got average 34 mpg. Bumped it up to 36 psi right now, average is around 36 mpg. Haven't gone any higher on psi. On stock steel rims with 185/60/15 tires at 35 psi, I was averaging 39 to 40 mpg.
I don't lollygag around town. I run 70 to 75 mph on expressway, 100 miles a day back and forth to work. Otherwise, would get run over in Atlanta traffic.
beaker is offline   Reply With Quote
Old 10-05-2014, 10:21 AM   #6
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
usually between 54-56 psi on either my summer or snow tires. I used to run 63psi in my old xB1 tires
If i know icy conditions are favorable I drop the snow tires to 38lbs
ive had like 20 tanks that averaged over 50mpg with a best of 54mpg.
lately I havent cared as much and been only getting 47mpg...which reminds me I really need to enter in my gas recipts into EcoModder...i have a pile of them
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 10-07-2014, 07:40 PM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I haven't a clue what my tire pressure is, I assume it is 32 like the door says. Last tank was 46 mpg.
Colin Chapman disciple
Old 10-07-2014, 08:39 PM   #8
sheekeebut
Minimalist
Drives: 07 silver sedan
36 psi fronts 38 rears. 7.3 l/100 km (32 mpg) because I love stop-and-go traffic and turns at every intersection.
sheekeebut is offline   Reply With Quote
Old 10-08-2014, 02:54 PM   #9
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
I am running with 35 PSI at this time. My current fuel economy is in the Fuelly banner below.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Old 10-14-2014, 04:14 PM   #10
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I run max in front, and a few pounds less in back (these particular 15's, crap S rated came with car) I run at 44 psi front and 40 rear, typically empty-ish load wise. Get 28-33 city and 38-41 highway....also spirited driver....
Old 10-16-2014, 07:09 PM   #11
Kar98
Drives: 2011 Scion tC
Great Scott!
Old 10-16-2014, 08:38 PM   #12
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
wow ..plain and simple and dont take this the wrong way but running tires at ur pressure is stupid and dangerous just to save on gas
The car is to be at specified tire pressure of 32 psi tires can take a max of on average 44 psi unless ur running E rate truck tire rated for 80 psi under max load . I honestly dont get ppl and i see this quite often , keep in mind the four patches under ur car is all u have from hitting a tree lol
Old 10-16-2014, 10:44 PM   #13
why?
why?'s Avatar
Drives: Yaris LB
32 psi is what the Toyota says for comfort, not what the tire manufacturer knows their tires can handle.
44 psi the max? Actually tires have different cold maximums on the sidewall.
10 extra psi is not going to harm anything. Tires must take much more so manufacturers won't be sued over exploding tires on highway in 100+ degree weather.
Old 10-16-2014, 10:56 PM   #14
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
True to a point but keep in mind a tire that is over inflated does not preform as intended .
Our car are to run at 32 for best of both worlds and a tire with 10 psi over the max is asking for trouble as u drive tire gets warm pressure goes up and so on.
I have seen first had what happens to tires that are over inflated and would hate to have a blowout while on a hwy and don't forget the wear and just a waist of tires just so u can get few more miles out of a tank.
Tire pressure can make or brake a car in how it drives ,handles etc do what u like I say but be safe about it not stupid cos of being cheap cos in the long run u pay more.
Just my 2 cents on that
sent from my S4 on Mars
Old 10-16-2014, 11:07 PM   #15
Hershey
The Altimax RT43 are 51 max . Still keep tires 34 > 36 for any tire . Didn't see much benefit in high p.s.i., only stiffer ride . During colder months try to keep them at 36. So when air pressure drops on those very cold nights or days they're slightly above or at 32 .
Old 10-18-2014, 04:51 PM   #16
kou
Drives: 08 lb
35psi in the tires and 10psi in the motor I average 36mpg.
Old 10-22-2014, 04:25 AM   #17
harda toenail
Drives: Want a yaris
36 PSI. 36 mpg. 50/50 city/highway
harda toenail is offline   Reply With Quote
Old 10-23-2014, 11:46 AM   #18
jay cobbs
Drives: 2010 yaris sedan 4 speed auto
I played a little game with myself when I first got my sedan yaris. Wanted to prove that if you drove like a prius and pumped the tires to about 36-39 psi that I could break the 35mpg in city. Remember I have a automatic but after learning about the yaris and prius having the same gas engine trick called DEFCO ( De-accelerate engine fuel cut-off ) at about 900-1100 rpm on the motor when slowing or "gliding " from stop to stop I got up to 41 mpg IN TOWN....YES, It is possable to do it with a auto. Yes, you will learn to listen to your motor just like a motor cycler does and back off the "petal" some. You must use TOP TIER GAS to pull it off ( Union 76-Chevron- or arco mid grade will work) and slowly start from stops with rpms below 1900. Have fun exploring what a YARIS is really built for...Endless possibilities and F U N. Enjoy
jay cobbs is offline   Reply With Quote
Broke 50 MPG STC Fuel Economy Forum 71 12-13-2010 01:04 PM
FE Turnaround: Disappointment to Satisfaction, 2010 Yaris. Almost +50 MPH. Thank You! STC Fuel Economy Forum 12 04-16-2010 11:21 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
195/60-15 Tires, premium and MPG Henry G. Fuel Economy Forum 24 09-10-2009 01:42 AM
