Old 12-31-2016, 02:01 PM   #19
chuckiek1
Drives: 06 Yaris
Torque setting for brake job
Thought this should be included here:
Caliper: 25 lb-ft, or 34 Nm
Caliper bracket: 79 lb-ft, or 107 Nm
Tyre lugs: 76 lb-ft, or 103 Nm
chuckiek1 is offline   Reply With Quote
Old 04-28-2018, 12:13 PM   #20
Runethecursed
Drives: 2009 Yaris S
Bump from the Graveyard but for any of you lurkers, You'd want to get the brake caliper from a 0-14 Scion XD OR 9-13 Corolla LE,STD model
If you are like me and hit up junkyards more often than you call your mum... itll be useful info
Runethecursed is offline   Reply With Quote
Old 10-22-2018, 03:01 PM   #21
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Just finished installing this setup on my car. It's actually the stuff in the pictures--bought them off Brushforhire after he totaled his. Install is super simple, barring any problems with stuck/rusted bolts. Still have to bleed the lines and refresh the brake fluid, but really looking forward to these!
Old 10-23-2018, 01:38 AM   #22
Runethecursed
Tell me how they feel, I put the bigger calipers on and while my booster might have been failing I hated the mooshy feel.
Time to replace rotors. Which brake upgrades? BennyLava DIY / Maintenance / Service 25 05-16-2016 05:57 PM
Problem removing front brake rotor jkuchta DIY / Maintenance / Service 24 02-27-2016 10:41 PM
Bolt Thread Size 4 Brake Drum Removal BobTheYaris DIY / Maintenance / Service 5 08-17-2014 01:14 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
