Old 03-28-2015, 02:27 PM   #145
Mikastef
Drives: Yaris
Can this work in an automatic gearbox?
Mikastef is offline   Reply With Quote
Old 03-28-2015, 10:28 PM   #146
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
No, the auto gearbox does not have the clutch lever. Must be something else.
Old 09-18-2015, 11:58 PM   #147
xdarkxfirex
Drives: 2015 yaris le
What about the automatic? I get a squeaking sound shifting into d or taking off most times
xdarkxfirex is offline   Reply With Quote
Old 09-19-2015, 09:33 AM   #148
Bluevitz-rs
1NZ-6spd Turbo
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS Turbo
could be a bad motor mount
Old 11-18-2015, 05:59 PM   #149
esse10
Drives: 2009 yaris 2 door
squeak
Anybody figure out how to lube the inside of the Clutch release fork boot pivot point? blue arrow in this picture.
File Type: png toyota-yaris-clutch-parts-components.png (36.9 KB, 167 views)
Old 11-18-2015, 06:02 PM   #150
tmontague
tmontague's Avatar
I just stuck a straw in there from a can of lithium grease and sprayed. I also sprayed it on all the shift linkages on top of the transmission. My squeak went away and has been for a couple months now.
FWIW I had a squeak when i'd depress the clutch pedal
I like to drive a slow car fast...
Old 11-18-2015, 07:23 PM   #151
esse10
ok
oh okay, I was skeptical about doing that cause you don't want to spray the clutch disc or something that'll cause more harm or start slipping. I was thinking if maybe I can get a camera probe in there to see what specific parts to lube or not.
Old 11-18-2015, 08:32 PM   #152
tmontague
tmontague's Avatar
I just made sure I didn't direct the straw directly in the direction of the clutch. Haven't had any issues since.
When I swap out my flywheel and clutch this summer i'll be adding a lot of grease to that area to ensure no sqeaking happens again.
Old 02-15-2016, 02:13 AM   #153
RiceCake
Drives: 2007 Steel blue yaris sedan
This is a definite fix!!! I've been looking everywhere for an answer and am so glad I stumbled upon this forum. So many useful guides!! Thank you again for the fix!
RiceCake is offline   Reply With Quote
Old 10-11-2016, 12:12 AM   #154
yarisgc
Drives: Yaris NCP91R 1.5 Man 5d Hatch
I had this little annoyance too (little squeak noise moving gears)
A couple of sprays of RP7 solved this for me, 2 1 second sprays once, leave 5 mins, then repeat with a 1 second spray on the area in the original posters pic, (thanks).
Yay! My first post, Hi people nice to meet ya :)
yarisgc is offline   Reply With Quote
Old 08-10-2017, 12:07 PM   #155
Kawiman
Drives: 2010 hatch
Wow!
I've got that ,too.
I can't believe it's so common.
I haven't gotten around to addressing it because i didn't know it could be so easily reached.
Thanks!!
Kawiman is offline   Reply With Quote
Old 09-18-2017, 01:54 AM   #156
komichal
Is this engine-dependent?
My Yaris 2007 uses 2SZ-FE engine and I am not able to find this part in the engine compartment...
Old 10-08-2017, 05:15 PM   #157
Kawiman
Drives: 2010 hatch
Thanks!
I used some product called Zep S 2000
It's clingier/stickier than WD40. And shouldn't just wash off.
The squeak is gone.
since I only heard it shifting into 2nd gear, I was affraid it was coming from the tranny.
Old 10-08-2017, 05:19 PM   #158
Kawiman
Drives: 2010 hatch
BTW
A Google search of a squeaking Yaris transmission sends you here...
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 05:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
