Old 12-19-2017, 06:42 PM   #379
stidnam
Drives: Starlet
Hi all
First time poster as well here after trawling through the site looking at 2zr threads :). I'm from Australia and it would seem nigh impossible to get my hands on the required brackets from a MT XD for a 2zr conversion. I've messaged every person wrecking a Scion XD on ebay only to be told they don't keep them.
Does anyone have an available source for these? I've also tried to purchase them new, but only one is showing as potentially being in stock - the RH one.
stidnam is online now   Reply With Quote
Old 12-19-2017, 08:08 PM   #380
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Originally Posted by stidnam View Post
Hi all
I got mine from the Toyota dealership, but I see full sets of mounts for sell on eBay. If you cant find used mounts you sometimes have to buy new ones.
Old 12-19-2017, 09:22 PM   #381
stidnam
Drives: Starlet
Yeah the mounts or isolators should be pretty easy to get a hold of, even in Aus. The parts I'm struggling to find though are the ones outlined in red. Based on the reading I've done, I need all 3 of these as well don't I?
Old 12-20-2017, 11:11 AM   #382
tmontague
tmontague's Avatar
Technically you can get away with only using the right hand side mount and isolator.
Do you have a lb or sedan?
I like to drive a slow car fast...
Old 12-20-2017, 04:27 PM   #383
stidnam
Drives: Starlet
It would be a hatch.
Or am I confused... If I buy the XD dogbone and the XD gearbox isolators, will they bolt to the Yaris equivalent of the parts I've outlined in red?
Old 12-20-2017, 08:45 PM   #384
tmontague
tmontague's Avatar
Yes technically they will bolt up albeit with some force of a pry bar and an extra hour and cursing to get the bolt through.
Based on my extensive experience of using all of the different types of mounts (xd and yaris) mate the proper bracket with its proper isolator to ensure ease of install.
The only difference is the xd mounts/isolators will place the engine a bit lower, slightly further away from the firewall and the way Toyota engineered it to sit. However using yaris mounts/isolators will also work as that is Tom's current set up I believe.
Either way you will need the right hand side mount and isolator from an xd as the yaris one will not work with the 2zr. The other two that both bolt to the trans case are fine to run either xd or yaris. If you run all xd mounts then it's recommended to run xd shift cables as the yaris ones are shorter and you risk snapping them
Old 12-21-2017, 03:47 AM   #385
stidnam
Drives: Starlet
thanks tmontague. Appreciate the advice.
I'll keep hunting for a full set of brackets. Sounds like that's the cleanest solution.
Old 05-31-2018, 07:59 PM   #386
DarkShadowFox
DarkShadowFox's Avatar
Drives: 2015 Yaris LE 3door HB
Cannot wait to do this to mine. hopefully it works.
Checkout My Build Thread: https://yarisworld.com/forums/showthread.php?t=58963
Im autistic about 3rd gen yarises. ask me anything.
DarkShadowFox is offline   Reply With Quote
Old 09-18-2018, 07:45 PM   #387
06YarisRS
Drives: 2006 Yaris RS
Originally Posted by ArmstrongRacing View Post
Here are the highlighted pins that need swapping.
1) If you keep the Yaris transmission: Move the speed sensor wires over to the same spots in the Xd plug CA2.
If the Yaris harness is removed and an xD harness put in its place, where do the 3 speed sensor wires that go into positions 11, 12 and 13 in the xD CA2 come from? Is there another harness that contains the speed sensor wires to be transfered over?
2006 Yaris 5 Door RS 2ZR-FE Swapped
2008 Yaris LE
2011 Kia Sedona LX
Old 11-07-2018, 02:32 AM   #388
ArmstrongRacing
Data doesn't lie
#3
Old 12-11-2018, 10:27 PM   #389
rallyxa
Drives: scion xa 2006 manual
planning on a 2zz swap into an 06 xa... i plan on using this thread for general guidelines as the comprehensive gist is pretty similar. gotta say that this is by far the most active and extensive thread for yaris swaps that i can find, and it really seems like OP knows what he's doing! big thanks to AR and everyone who contributes for the help!
feel free to shoot me a different direction if you see fit!
rallyxa is offline   Reply With Quote
Old 12-11-2018, 11:04 PM   #390
ArmstrongRacing
Data doesn't lie
A 2zz swap will be awesome, make sure to create your own thread to share the journey
Old 12-12-2018, 07:02 AM   #391
06YarisRS
^ I will be watching this, big time!
2008 Yaris LE
2011 Kia Sedona LX
Old 12-12-2018, 08:10 AM   #392
Bluevitz-rs
1NZ-6spd Turbo
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS Turbo
Just so you’re aware, a 2ZZ will involve cutting the frame to get it in.
Old Today, 06:25 AM   #393
rallyxa
yep, basically gaining 99% of my knowledge from YT vids... saw on AR's channel what will be involved for the cutting of the frame near the tranny.
my hopes are that the sizes of the 2zz vs the 2zr with a c60 are identical and that the engine bay dimensions in that of the yaris are also the same as the xa bay. along with distance between the hubs. i will have to find out if the axels from a celica will fit as well.
IF the dimensions mentioned above are all luckily the same, my next question is, how did the xd axels fit from the c60 trans to the yaris hubs? new distance (2zr w/c60 in yaris)was spec for the xd axels?? and then i gotta see if it works in my engine bay with celica axels and a 2zz.....
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 05:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 07:56 PM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
