Old 04-20-2017, 06:28 PM   #433
tmontague
tmontague's Avatar
Originally Posted by NYC-SE View Post
I'll be inspecting them every year going forward.
FYI, I had also originally planned on pulling the bolts once per year but after coating them virtually the same as you and pulling them to inspect after 1 year, I now just check them every 2 years. Even at 2 years they're virtually untouched.
It's your call but I figured I'd give my input to save you some hassle as your roads are similarly coated in brine for 4 months of the year like ours are.
I like to drive a slow car fast...
Old 04-20-2017, 09:16 PM   #434
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
I think I'll pull them in a year anyway just to satisfy my curiosity. I would expect them to be in good shape. After that probably every 2 years. I figure if they can survive for 3 years with no protection they should be fine after 2 with a good coat of grease.
Old 04-22-2017, 07:58 PM   #435
Cartel
Cartel's Avatar
Drives: 2007 Yaris Hatch
toyota pig iron...I'll have to inspect mine after seeing this disaster
Cartel is offline   Reply With Quote
Old 09-10-2017, 03:38 PM   #436
bladesmith6
Drives: 2007 yaris HB
Warning
Well i finally checked mine on my 2007 and glad i did, the driver side was looking really bad. Well coated the new ones in grease and installed with no real drama.
bladesmith6 is offline   Reply With Quote
Old 09-13-2017, 10:53 PM   #437
jayeh
Drives: '08 Yaris LB
Originally Posted by RichardPan View Post
My 07 sedan is now 10.5 years old, and I live in Ottawa, Canada, where road salts are just a fact of life. Would it be a good idea to find a mechanic to replace the bolts, before it snaps? Seems like this potential problem would be the last remaining item that would limit the service life of my Yaris. It has only 130k km on it, and engine/transmission seems to be in good shape.
I had my old mechanic in Ottawa switch mine out. My car is a 2008 and they were replaced in 2012-14 sometime ( I can't remember!) and snapped when they were extracting them. Luckily they welded on a bolt and were able to extract them that way!
I'd get on it ASAP!
jayeh is offline   Reply With Quote
Old 12-09-2017, 04:38 PM   #438
yaris2011-07
Drives: 2008 yaris hb ce
Replaced bolts
I was able to get the bolts on my Yaris replaced. The passenger side came out without breaking. I wasn't so lucky with the driver's side.
The attached images are the driver's side bolt from a 2008 Yaris Hatchback after 10 years and 70K kms.
The new ones have been installed with lithium grease.. should last longer!
yaris2011-07 is offline   Reply With Quote
Old 12-09-2017, 06:29 PM   #439
NYC-SE
NYC-SE's Avatar
My God, I think those are the worst I've seen yet!
Old 12-09-2017, 09:14 PM   #440
tmontague
tmontague's Avatar
How was the broken bolt extracted?
Old 12-10-2017, 12:20 AM   #441
yaris2011-07
Yup, looks bad. I needed to drop the subframe and then heat up the bolt bolt with a propane torch. Once heated, I used a good pair of vise grips and was able to remove the bolt.
The most difficult part of this procedure was getting the control arm bushing to release the bolt since the bolt was rusted solid to the bushing sleeve.
Old 12-10-2017, 09:21 AM   #442
dogsridewith
Drives: 2007 2-door hatchback
Warning - Broken control arm bolt! subframe Mind of Toyota
I think this may happen because Toyota skipped a drain hole(s) somewhere. I did an oil change in dry conditions a day after I'd washed the car or there had been a rain event. Car on a lawn sloping somewhat nose down. Drove front wheels up on low ramps to level for oil change. Some time passed in steps of the oil change. And here's water dripping from that subframe area! (pretty sure I checked to see that it wasn't coming from the rubber HVAC tube)
(Warning - Broken control arm bolt! subframe Mind of Toyota)
Old 12-10-2017, 08:21 PM   #443
tmontague
tmontague's Avatar
I had the same issues on my '05 vibe when I replaced the control arms, took an extra 6hrs and I ended up having to burn out the bushing and enlarge the subframe hole to fit the metal insert through. It was seized so bad I never got it unstuck. An impact was useless as the bushing dampened the impacts.
Now on any car I own I pull the control arm bolts and antiseize the whole thing so it never seized to the bushing sleeve. Takes some time but saves hours down the road
Old 12-10-2017, 09:53 PM   #444
yaris2011-07
Agreed. Some extra drain holes or extra sealing to prevent water from entering the bushing sleeve would help to prevent this situation.
Old 12-10-2017, 10:01 PM   #445
yaris2011-07
I also ended up burning part of the bushing while lowering the subframe.
I torched the bushing sleeve a number of times, so the heating and cooling process along with alot of hammering on the bushing sleeve helped to release it from the bolt.
Old 02-01-2018, 04:27 PM   #446
Cartel
Cartel's Avatar
I'm trying to show a local shop theses pictures and its useless linking this thread cause you dont display the images without signing up first.
thanks
Old 02-02-2018, 01:31 PM   #447
thetut
Drives: 2007 4dr sedan
Right click on the image.
Select "Copy"
Open Paint program
Select "New"
press Ctrl + V
Save file and copy it to your phone or tablet.
Show it to your mechanic and let him revel in the destruction.
thetut is offline   Reply With Quote
Old 02-02-2018, 07:20 PM   #448
Billiam
Drives: '10 White Yaris 4D LB
We bought a '10 LB a couple of weeks ago with 126k on it. The 1st thing I did was change the oil to some M1 High Mileage 5/30. The 2nd thing I did while it was on the ramps was to check these infamous bolts. I was very nervous putting the breaker bar on them. Thankfully they both came out with out any drama. Despite water dripping from the passenger side hole when the bolt was removed, both bolts looked great. I lathered them completely in antiseize as well as the holes and reinstalled them.
I'm way out of warranty and on my own. So checking these will be part of my regular maintenance
If you want to enjoy your car, stay off of the internet.
Old 02-02-2018, 11:33 PM   #449
Cartel
Cartel's Avatar
Well I ordered the bolts.
Toyota argued with me about the part number and how they are non-returnable.
Apparently 90119-14126 was superseded by 90119-14144 and 90119-14151 wouldn't match up for him, he basically talked me into getting the 14144 bolts.
I pulled mine out, the drivers was pretty loose.
I then dipped the new bolts in marine grease from top to bottom and made sure they were really gooped up with excessive amounts of grease and put them in.
My car has under 45,000KM on it so they were not bad.
The bolts were $26 CAD for both.
I cranked the wheel to one side and layed beside the car to get them out without lifting it.
I wanted the garage to just inspect mine while getting a wheel alignment next week but decided to just replace them myself first.
The new ones only had 1 mark compared to 2 on the original.
Old 02-03-2018, 12:27 PM   #450
tmontague
tmontague's Avatar
those are in decent shape, keep them as spares just in case
the marine grease has worked well for me and I now only check them every couple of years as the water seems to keep away from the marine grease really well
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 305 08-30-2018 03:21 PM
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 458 05-20-2018 11:35 AM
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 123 11-17-2016 11:41 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
