Old 02-02-2018, 05:28 PM   #1
nemelek
DWEED
nemelek's Avatar
100K Water pump and drive belt
Picture of old parts at 100,000 miles. Glad I changed them out. Thanks to this Forum and members for their pictures, procedures and advice. Took three hours.
Old 02-05-2018, 08:33 PM   #2
zoidberg444
zoidberg444's Avatar
Did you use an OEM drivebelt? I had mine replaced at 9 years old when the voltage regulator in my alternator went bad and the mechanic replaced it with a Dayco belt which squealed like crazy for no reason a little over a year later.
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 160,000 miles
UK to Nordkapp in a Yaris
Old 02-05-2018, 08:55 PM   #3
xdarkxfirex
Drives: 2015 yaris le
Yes you are right. The aftermarket parts suck on these cars. If you are going to use other than anything from the dealership, stick to bando or mitsuboshi. They make the OE belts.
xdarkxfirex is offline   Reply With Quote
Old 02-06-2018, 01:10 PM   #4
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Over the 4-5 years I've owned my current yaris, I have replaced the drive belt 4 times (the 4th one last weekend). Each time because it starts squealing at startup, even after re-tightening. Each time with a different brand from the local shops. Cheap or expensive, it makes no difference. This last time I just took it to the shop and had them do it. At least now if it starts doing it again I can just take it back to them and say "fix your crap". Lets hope 4th time is the charm.
Old 04-20-2018, 06:22 AM   #5
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
I was just watching a youtube video about a guy who claims that you can make your drive belts last hundreds of thousands of miles with a product designed to polish tires.
https://www.youtube.com/watch?v=dRXkt6Dgi4k
On another note, did you replace the water pump with an OEM Aisin one from Toyota, OP? There was another thread on here where everyone complained that the new OEM waterpump would start leaking every 30k miles.
07liftback is offline   Reply With Quote
Old 04-20-2018, 03:36 PM   #6
Secretblend
Drives: 2009 Yaris
https://www.youtube.com/watch?v=HRrVMtyIqIY
Check this video out and see if it helps with your belt squealing.
Secretblend is offline   Reply With Quote
Old 04-20-2018, 06:27 PM   #7
maui
Drives: 2008 Yaris hatchback in white
very useful, this after having fabricated a belt tensioner from a post on how to solve this extremely annoying problem. It also explains why at times it does not squeal, probably just started the car a little slower...
maui is offline   Reply With Quote
Old 09-03-2018, 07:25 PM   #8
Tedtalker
Drives: 2007 Yaris Sedan
I just installed a new Dayco Poly Rib belt on my 2007 with 75,000 miles. Engine ran much better and so much smoother. I wasn't expecting a better running engine. I just thought I better replace it after 12 years and 75K. My OEM belt never squeaked or chirped ever and this Dayco Poly Rib is silent as well. Before I loosened the alternator bolts I marked around the bolt washer with a sharpie pen. Tension-ed the new Dayco at the exact marking and it seems perfect. Maybe it's the Dayco Poly Cog belts that squeal? My Poly Rib said made in USA on the belt. Good enough for me.
Yaris - It's A Car !
Tedtalker is offline   Reply With Quote
Old 09-04-2018, 06:20 AM   #9
dogsridewith
Drives: 2007 2-door hatchback
Serpentine belt tension adjustment water pump bearings
Absolutely not a way to set new-belt tension.
(Serpentine belt tension adjustment water pump bearings)
Old 09-06-2018, 08:20 PM   #10
Tedtalker
That was the factory setting dog. It was exactly where the factory tech placed it. I figured it was a good starting point before FINAL tension setting after the new belt stretch. My tension tool is on the way.
Old 09-07-2018, 08:23 AM   #11
dogsridewith
Water pump serpentine belt tension tensiometer
No way. Good chance you're killing the water pump bearings. Running too tight wouldn't help the belt either. (How do you think you would be able to know too-tight by observation...when saying "seems perfect?")
By the way. The manual's serpentine belt tension treatment is a Mind of Toyota cluster-fluff. I won't recommend a method for anyone else, but mine is an initial set to not-too-tight by feel, matchmark, and tighten in tiny increments when hearing a chirp at startup. (I'd carry tools if making a trip on a new belt.)
I'm tightening by a 13 inch channel lock plier w/ jaws on the end of the curve-slot adjuster bar and the alternator's upper bolt boss. (Toyota manual wants prybar but be careful to miss the critical mechanism right there some where hard to see and same color as the other metal engine parts.)
Old 09-07-2018, 09:14 AM   #12
zoidberg444
When I set the tension on mine I set my calipers to 11mm and rested them on the longest run of the belt in the middle with one hand and deflected the belt with my thumb. It was probably a little loose but it didn't squeal. The belt I'm using is a Chinesium Blue Print belt. So far it's been silent unlike the Dayco belt that was on there before which squealed for no reason whatever the adjustment.
Sent from my SM-G900F using Tapatalk
Old 09-07-2018, 10:18 AM   #13
dogsridewith
serpentine belt deflection specification Toyota Yaris
Toyota also gives "Deflection" specs for new and used belts. But it is a meaningless number without prescribing the applied perpendicular force that causes the measured belt deflection.
Old 09-09-2018, 07:09 PM   #14
Tedtalker
Thanks for the heads up. I did the 90 degree twist method after setting it where the Toyota tech set it. Seems right on but I will of course check it with my new v-belt guage when it arrives. (fFrom the Web) Place a belt tension gauge in the span shown and tighten the belt until the tension reads 102-123 ft.-lbs.
If you don't have a tension gauge, just measure the deflection of the belt in the span area shown in the illustration. When properly tightened, the belt should deflect .410 to .450 inch. I did put the wrenches in my car after the install. Just in case
Old 09-09-2018, 07:13 PM   #15
Tedtalker
Was your Dayco belt the Poly Rib or Poly Cog? My Poly Rib is silent.
Old 09-19-2018, 03:25 AM   #16
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
My series 3 manual lists the deflection specifications in both metric and imperial measurements. On the longest section of the belt between the crankshaft pulley and alternator pulley there should be 12.5 to 13.5 mm (0.49 to 0.53 inches) deflection at the centre of the belt for 10 kg (22 pounds) of applied force.
The same measurement is listed for both 1NZ-FE and 2NZ-FE engines.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, switchback LED DRLs and dash cam. Still to do: better horn(s).
Old 09-19-2018, 05:03 AM   #17
bronsin
bronsin's Avatar
The belt on my wife’s Camry was replaced at 150,000 miles and according to the gauge the gates makes it was still serviceable
Old 09-20-2018, 07:16 PM   #18
Tedtalker
At twelve years and 75,000 miles my factory belt was dry and brittle. Had cracks all over it. Very glad I changed it.
2008 Yaris knocking/rattling sound near drive belt avs262 DIY / Maintenance / Service 4 07-21-2015 05:34 PM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 01:33 PM
change water pump n something is shifting susucosp DIY / Maintenance / Service 1 10-04-2013 02:23 PM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 05:00 PM
Squealing after water pump blew euroa4 DIY / Maintenance / Service 11 06-10-2010 03:18 PM
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
