11-08-2018, 09:30 PM | #361 | |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
11-09-2018, 12:31 AM | #362 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
I'm on board, PM me with your paypal info
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-09-2018 at 02:05 AM. |
11-09-2018, 05:43 AM | #363 |
I found a much better price Tom. The guy from England emailed me back and he can deliver 6 of these emblems for $120.00 USD. Maybe we could have them delivered to a central location and redistribute from there. Or, I could ask him shipping quotes for each individual piece to different addresses. If you can PM me an email address, I can send you the email. I'm not sure how many we need all together, and maybe the guy could offer a similar deal for a smaller number.
EDIT: Here is link to the listing he created: https://www.ebay.com/sch/i.html?_fro...01565&_sacat=0 I would like to contribute financially. I would also offer to receive them and mail them out to the recipients. Thanks Just to confirm, here are the pics of his product:
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-09-2018 at 06:07 AM. |
11-09-2018, 08:04 AM | #364 |
Be warned guys.
The sedan and hatch do not share the same front grill insert design. I'm willing to bet that the clip in badge will only work on the hatch. I have seen another badge which mounts via a single pass thru bolt which facilitates universal mounting. Sent from my EML-L09 using Tapatalk
11-09-2018, 08:10 AM | #365 | |
11-09-2018, 11:30 AM | #366 | |
Data doesn't lie
Im still interested, let me know how to proceed |
11-09-2018, 12:47 PM | #367 | |
Adam
11-09-2018, 01:25 PM | #368 |
I wanna be part of the TS crew
11-09-2018, 07:04 PM | #369 |
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-09-2018 at 09:14 PM. |
11-09-2018, 11:46 PM | #370 |
Just scored on eBay $100.00 + $50.00 shipping...
11-10-2018, 02:36 PM | #371 |
11-10-2018, 06:52 PM | #372 |
Seriously? Is it going to sound like a fart can? I don't like the sound of that, literally and figuratively.
11-10-2018, 08:01 PM | #373 |
Data doesn't lie
I don’t think so, as long as you keep 1 resonator you should be fine
11-10-2018, 08:25 PM | #374 | |
Thanks. That's good to know. I will definitely be keeping the resonator and both cats. Just need to upsize the pipe from the resonator to the axle.
11-10-2018, 09:09 PM | #375 |
11-10-2018, 09:28 PM | #376 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
Yup keep the resonator for sure, it's a well flowing 2 5' open pipe iirc and it does a lot to remove the rasp
No one ever wants to give a Yaris the point by... |
11-10-2018, 09:39 PM | #377 | |
I will indeed keep the cats and resonator. Thanks!
11-10-2018, 09:49 PM | #378 | |
Before I found the Megan axleback- and was going to use that other muffler I got - I had talked to an exhaust shop. They said that I should remove the flanges at the muffler and end of the midpipe and have on continuous pipe, bent over the axle. I don't really like the idea of hacking the end off the Megan and welding directly to it. What would you do in this case? If the Megan is designed to attach to stock Yaris exhaust, it must be a smaller diameter, wouldn't it. Would this small area of smaller diameter cause a restriction in flow?
Thread Tools | |
Display Modes | |
Similar Threads | ||||
T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
