Old 12-06-2009, 02:28 AM   #19
advocate
Drives: car
Originally Posted by tamago
STAGE 1
Simple, inexpensive mods that will increase the fun factor of your ride.
* Lightened Pulleys - NST has a full range, but you can just start with the crank pulley. These increase the responsiveness of your engine by lowering rotational mass. On the down side, they can make driving smoothly a little more difficult, especially on manual transmissions.
* Good Tires - This is really self-evident, tires are the only contact between your car and the road. Street-rated sport tires are a good compromise for a daily driver which sees occasional racing action. You can also at this point change your wheels, if you're really after performance, you should not go over 16", as bigger wheels are heavier, which will sap a lot of the limited power available.
* Short Shifter - If you have a manual car, this is a must. You'll shift between gears faster, meanign less "dead time" when you are not accelerating. Three options here, NST or TRD which are installed in the engine bay, shortening the lever action on the gearbox, or TWM's which is installed in the cabin, essentially a shortened version of the stock gear stick. it makes for a nice cosmetic improvement too, but may be harder to reach.
* Lowering Springs - Several advantages here, first it makes the car look a lot better, secondly it improves handling somewhat by limiting body roll. Quite a few choices here, Tanabe and TEIN's offerings are quite popular, but there are several others.
* Tie Bars (aka Strut Bars) - The efficiency of the front tie bar is a disputed issue, but it is meant to strengthen your car under heavy cornering, giving more steady, controllabe handling. Rear strut bars are also available, and other underbody stiffening braces if you are feeling adventurous
* Intake and Axle-back Exhaust. On this car, most of the aftermarket intakes and exhausts do not bring a whole lot of power to the table, and if they do, it's mainly at high RPMs. Still, they can dress up an engine bay/rear end of the car, and give a much more sporty sound to the car (which will make it feel faster too ) Many many different brands and models here! We have a few members who have run their cars on a dyno after installing these, aftermarket headers (also known as I-H-E combo), and crank pulleys, it is good for about 10-15HP gain at the wheels.
Please refer to this thread for most of your needs and areas to research:
Tamago's Amazing Guide
Old 12-10-2009, 10:30 AM   #20
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
yea so far on my yaris automatic i have TRD CAI, tein s springs, nst lightweight pulleys (10% UD crank, wp, and alt), Nitto axleback exhaust...15" konig lightweight rims
tell you the truth im done with performance mods, not much power gain from it, the only mod that i noticed a difference is the NST pullys that was the biggest difference the rest i notice nothign but sound difference :).
But i was in the same situation as many of the others who posted, i graduated and was given the yaris as a gift...yaris sedan AT :(. but i haven't added any mods since last summer, im planning on putting it back to stock sometime soon and buy a new car to work on, im looking at the Volvo C30, its pretty nice and its different not many people mod those cars plus its small like the yaris, im kind of used to it now
Aothachos is offline   Reply With Quote
Sedan mods Arkhangel Cosmetic Modifications (Exterior/Interior) 21 03-15-2009 12:59 PM
Toyota Australia releases YRX SEDAN. Sp33dY General Yaris / Vitz Discussion 1 08-01-2006 01:19 AM
