Old 08-02-2021, 10:58 PM   #1
billfires
Drives: 2010 3dr LB
Bad fuel pump
After spending a good portion of the day trying to find an E10 Torx socket (to remove the rear seat) and then removing 7 bolts (with one snapping off and needing to be drilled out), I was finally able to test and verify that the fuel pump is no good. What has everyone been using for a replacement assembly? Thanks for any suggestions. Bill C
billfires is offline   Reply With Quote
Old 08-03-2021, 05:42 AM   #2
bronsin
bronsin's Avatar
What year is your car and how many miles?
Old 08-03-2021, 08:17 AM   #3
billfires
Drives: 2010 3dr LB
2010 2 dr HB with 190,000 miles. I fill it at 200 miles. so no idea what happened. Bill C
Old 08-03-2021, 11:44 AM   #4
bronsin
bronsin's Avatar
I believe Toyota only sells the entire assembly complete with fuel filter and I bet that’s expensive. If you can do it I would just buy a motor and swap him out. Of course you would want to replace the filter too.
Good luck and tell us what happens!
Old 08-06-2021, 09:03 PM   #5
billfires
Drives: 2010 3dr LB
Amazon fuel pump assembly delivered and installed. Fuel guage not working but car is running awesome. Took a chance with an Amazon Warehouse pump ($75.00) and it was fine. The fuel assembly is not in the exact same position as the original so that may be the problem with the sender.
Would you put a new fuel pump in the original assembly to keep as a spare? Bill C
Old 08-07-2021, 07:00 PM   #6
billfires
Drives: 2010 3dr LB
Update, car would not start at McDonalds (but fuel gauge was working). Checked electrical connection and hoses. Won't be able to get to it until Monday morning due to fire department details earlier today and tomorrow. Bill C
Old 08-08-2021, 06:13 AM   #7
bronsin
bronsin's Avatar
No fuel pumps run a long time And your car is very old.
Old 08-08-2021, 06:14 AM   #8
bronsin
bronsin's Avatar
Yikes! You may have a bad pump there.
Old 08-20-2021, 04:17 PM   #9
zoidberg444
zoidberg444's Avatar
Honestly mate - considering what a ball ache it is to do a fuel pump I would use a Denso pump to replace it with. That was probably the OEM fuel pump brand from the factory. If you put your VIN in on toyodiy dot com you can find the OEM part number and probably track down the Denso equivalent on a parts website somewhere. Yoyo part often cross references the OEM part number with the various different brand part numbers. It's what I would do. Your fuel pump was pretty old and with all the ethanol they put in the fuel these days they don't last like they might have in the 90's.
That amazon pump was probably some random Chinese one that probably won't be reliable or last very long.
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
Old 09-08-2021, 07:47 PM   #10
billfires
Drives: 2010 3dr LB
Just wanted to update everyone. Got the car back today, it was the Cam Position Sensor. I needlessly replaced the fuel pump because I didn't check for fuel flow. I got stubborn and registered my 10,000# trailer and then spent 3 1/2 hours trying to load the car on. Bill C
Old 09-09-2021, 04:23 PM   #11
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Live and learn. At least your car has a new fuel pump now.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 05-17-2022, 02:11 PM   #12
mik36
Drives: VERSO S
How cam shaft sensor is related to fuel system ?
mik36 is offline   Reply With Quote
Old 05-19-2022, 04:33 PM   #13
billfires
Drives: 2010 3dr LB
The camshaft position sensor had nothing to do with the fuel pump. I didn't properly troubleshoot the problem and thought it was the fuel pump. It was the cam position sensor all along. Bill C
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 324 02-29-2024 06:43 AM
intermittent fuel pump start kaypie DIY / Maintenance / Service 2 02-04-2021 07:10 AM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Aftermarket Fuel Pump BoostedTRD Forced Induction Forum 5 10-29-2014 04:31 PM
Fuel Pump Failure eaglerox DIY / Maintenance / Service 14 03-02-2013 10:27 AM
