02-08-2014, 09:55 AM | #1 |
squealing belt, but a different question
Ok, I have read over and over about the startup squeal of the Yaris belt when it is cold.
I have put on a new Bando belt, but it still squeals. I read that you need to ensure the pulleys are dry and clean before installation of the new belt so as to ensure nothing is helping it slip. My question is whether it is ok to use brake cleaner, sparingly, to clean off any residue from the pulleys (belt removed already of course). Thoughts? |
02-08-2014, 11:35 AM | #2 |
Drives: 2012 Toyota Yaris sedan Join Date: Aug 2013
I've been having this same issue on my 41k miles old Yaris. I turn the keys, & as SOON as the car's started I let go of 'em, yet the squeak still persists, though mostly only when it's cold outside or the car hasn't been cranked in like half a day & has cooled down.
Methinks it's coming from the belts, so I'll have to check it out. |
02-08-2014, 12:44 PM | #3 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Cleaning the pulleys is not a bad idea, in case a bit of oil got dripped from a prior oil change. If the belt is properly tensioned, but still squeals, that could indeed be the problem.
Brake cleaner would be fine if you sprayed it on a rag, rather than spraying it on the pulleys (where it could end up where it should not be). I typically use denatured alcohol for that type of cleaning.
02-08-2014, 01:52 PM | #4 |
Drives: toyota yaris yrs Join Date: Jun 2007
I would go with OEM toyota belt and to get right tension requires a use of a pry bar makes sure you wrap the pry bar with the cloth and pry it against the engine mount.
02-09-2014, 12:41 PM | #5 |
Drives: Echo RS Join Date: Aug 2006
Similar Threads | ||||
Easy fix for Squeaky / Squealing Belt | andrewmcg | DIY / Maintenance / Service | 42 | 11-08-2017 05:26 PM |
Squealing Belt Noise | Toyota3000 | DIY / Maintenance / Service | 3 | 07-23-2013 03:06 PM |
squealing belt | dferguson2 | DIY / Maintenance / Service | 9 | 06-19-2012 11:13 PM |
Squealing Belt | rossman | DIY / Maintenance / Service | 8 | 01-31-2012 01:58 PM |
Drive belt question | toyo | DIY / Maintenance / Service | 4 | 02-22-2010 07:42 PM |
