05-11-2014, 03:38 PM | #1 |
Drives: Toyota Yaris Hatchback 08' Join Date: Aug 2013
Help me with my deteriorating fuel economy
:( my little car, Yari, is very much lacking in fuel economy right now. I got her last May and from May 2013 to about September 2013, I would get about 85-100km per bar on my dash. It then slowly got worse and is now at about 50-60kms per bar. Literally half of what it was. I got new all seasons in November. I've checked my air filter and a friend of mine took a look at things in my engine and said it all looked normal. I drive the same amount and just as calmly. Weather was cold in the winter but it's warm now but no improvement as far as gas. I don't know what could change my fuel economy that drastically. Any ideas??
05-11-2014, 07:07 PM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
How many miles do you have on it? There are many things that could be contributing:
1. Dirty MAF sensor 2. Failing O2 Sensors 3. Dirty fuel injectors 4. Plugged Cat 5. Fouled plugs 6. Weak coil packs etc.
05-11-2014, 07:09 PM | #3 |
Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
Make sure your tires are inflated properly. I would try the 32 PSI that Toyota recommends for the Yaris. Also try the PSI recommended by the manufacturer of your new all season tires. Your new tires might weigh more than the previous tires, and that might make a small difference re MPG. Also, are you sure you have proper wheel alignment ?.....and...Are you sure the tires were balanced properly during installation (most places have a machine, so I don't think that is usually an issue) ? Do change just the tires, or did you also change the rims ?
Some people get better MPG running higher than recommended PSI in their tires. This was true for me (In multiple cars over the years) until I (6 months or so ago) reduced my PSI from 38 to 32, and my MPG actually improved. |
05-11-2014, 07:26 PM | #4 |
I was in the middle of typing my post when CTScott posted (two minute difference). Listen to CTScott. My suggestions might make a little bit of difference, but I would think the 6 things CTScott mentions would each make more of a difference re MPG than my suggestions. The only one of those I can really comment on re personal experience with my own cars is #5. I kept the same spark plugs in my Suzuki Swift from new to the end (151,000+ miles) and didn't notice the MPG drop as the plugs aged. I didn't get the spark plugs changed in my Yaris until about 208,000 miles, and I also didn't notice a drop off in MPG as the spark plugs aged. However, these might be two outlier experiences, and not even close to a normal experience.
05-11-2014, 07:34 PM | #5 |
Drives: 2009, auto, 4dr LB Join Date: Nov 2010
Best mileage in the summer, worst mileage in the winter, Canada no less. Sounds like me. I can go 6-8 mpg difference from summer to winter. Let me guess short commutes? You say it's warm now, here in MA. my "cool" engine light is still on in the morning when I get in my car and start it and go.
When I drive out to Ohio, my Ultra-Gauge monitors intake temp, and as I go through western PA at elevation the intake temp will drop sometimes 5-10 degrees and subsequently instant mpg falls off accordingly as the temp drops. My suggestion when these mileage things come up is ignore the "bars" Go strictly by miles per gallon or liter. Fill it up and go for a 4 hr. drive on a highway, cruise control if you have it and then check your mileage. Auto or Manual? It may never be getting out of 3rd gear. or only briefly Last edited by NEexpat; 05-11-2014 at 07:51 PM. |
05-11-2014, 08:04 PM | #6 | |||
05-11-2014, 07:58 PM | #7 |
Only Happy When it Rains
also have you changed your oil, and does the transmission fluid need to be changed? These things can make a significant dent in fuel economy as well.
Colin Chapman disciple |
05-11-2014, 08:06 PM | #8 |
05-11-2014, 08:25 PM | #9 |
" If I'm getting really close to empty, I still do pay attention to the bars, but I pay much closer attention to how many miles I've driven on that tank and what my MPG was on the previous tank."
Nook, you are quite right. It was my own clumsy phrasing. What I should have said is the "bars" are not nearly as accurate as actual miles or kms per gal. or liter. I've had 1st bars drop as low as 59 and as high as 107. But don't ignore them. Cheers. |
05-12-2014, 12:04 AM | #10 |
77,000kms, automatic, oils all good etc! Should I run it to absolutely empty and see how many kms my whole tank gets me?
05-12-2014, 08:13 AM | #11 | |
You can then determine if you are doing very bad or not. |
05-12-2014, 02:52 PM | #12 |
Drives: 2012 Yaris L, 2020 Yaris LE HB Join Date: Jan 2013
If it is available in your area, check to see if you can purchase non-ethanol gasoline. In my experience, this make a big difference. Though, there is a cost factor involved.
06-04-2014, 01:27 PM | #13 |
@ mygirlYari: Do you have any updates?
Tags |
poor fuel economy gas |
Similar Threads | ||||
Do any Yaris owners use premium gas ? | DanMC | Third Gen Yaris General Discussion | 38 | 11-06-2013 10:36 AM |
Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
Forced Induction and Fuel Economy | ellenbetty | Fuel Economy Forum | 11 | 08-13-2009 01:12 AM |
