Old 05-19-2015, 11:15 AM   #1
Blanketnam
Drives: Toyota Yaris Zen 2011 HB
Weird clicking noise from front right wheel - low speed
Hi All
My 2011 yaris zen 3 hatchback has now started making a strange sound when driving very slowly. It almost sounds like something is rolling around in the wheel rim. It's a metallic sound.
But, I only hear it at very low speeds, like below 15kph, if I roll my window down (right hand steer, front right wheel makes the noise).
I can hear it more clearly if someone else drives and I walk next to the car.
Could it be something inside the tire? It doesn't have a puncture so I can't think that something is inside the tire.
Any help would be appreciated!
Blanketnam is offline   Reply With Quote
Old 05-19-2015, 12:01 PM   #2
tmontague
tmontague's Avatar
Could be a stone stuck in your tire or brakes. Check your tire first than remove the. Wheel and inspect the brakes. I'd also check for play in your wheel when the car is liften off the ground
Old 05-19-2015, 03:58 PM   #3
Blanketnam
Talking
Thanks!
I removed the wheel, and found a small stone inside the brake disk! There is a metal plate behind the disk that prevented the stone from coming out. Forced it away gently and spun the disk until the stone came out.
Tags
clicking, front wheel, low speed
Low road noise in Yaris? RedRide General Yaris / Vitz Discussion 32 05-30-2010 08:49 PM
Weird Clicking Sounds Itsnhi DIY / Maintenance / Service 6 12-22-2009 06:30 PM
Weird Squeeking noise after lowering Riced-yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 05-22-2009 04:04 PM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
